Newer Air Conditioning
Discussion in 'Technical' started by Phil, Oct 23, 2016.
  1. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    Hello all, I tried a search, but couldn't find any good details. I have a newer fuel inject 5.0, and A/C compressor in my maverick, the previous owner swapped out the airbox/controls for one with A/C. It has the evaporator in there, but nothing else. What do I need to do to make this system work with the newer compressor? I know i need a condenser, lines (do they need to be custom, can i make some stock ones work?), and can i use the current evaporator, or should i try to make a newer foxbody one work with an orifice tube? I know this is a complicated question, but i'm hoping someone has done this before.
    -Phil
  2. 71gold
    I had stock A/C that all I did was change the compressor, new lines and add a trinary switch...
  3. 71Mavrk
    71Mavrk Member
    Nevada
    I retained everything as stock except for the compressor and custom hoses.
    Micah
  4. rthomas771
    Replace the expansion valve while you at it
  5. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    What did you have to do in the way of custom hoses? What fittings are different? Have any pictures?
  6. mojo
    I wud contact one of the AC firms to get a complete hose/fitting kit,, that way, you have all the parts needed to measure and clock the fittings to be crimped. I got my complete underhood setup from Classic Auto Air - all you need is the hose/fitting kit. My setup does not have a trinary switch, (that I am aware of), maybe I wire one in at some point.
    I wud replace the drier and expansion valve, if you have not done so. I have had gud working relation w/ Classic.
    I will look for some pic later or take some if I can't find them on the hd.
  7. 71Mavrk
    71Mavrk Member
    Nevada
    The modern compressor is completely different than the original in both design and mounting.
    Micah
  8. Wizz
    Wizz Member
    Oakland,ca
    1977 maverick
    What Serpentine system are you running its clean
  9. 71Mavrk
    71Mavrk Member
    Nevada
  10. 71Mavrk
    71Mavrk Member
    Nevada
    Another shot:
  11. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Everett, what is that power steering pump setup you have on there? Looks like it may solve my problems.
  12. mojo
    What issues are you having?
    I have a Saginaw "GM" style pump. I have a Borgerson steering conversion bought as a kit. I have seen the Saginaw pump used w/ OE Ford steering boxes. You may want to search around for what is involved w/ installing GM pump as far as, brackets and pressure adjustments.
  13. jasonwthompson
    Carrollton TX
    I was looking for something that sits lower and a bit farther out from the fuel pump. Looks like what you have does the trick.
