Nitrous question
Discussion in 'Drag Racing' started by Butters, Apr 20, 2016.
  1. Butters
    Butters Member
    Colorado Springs
    1970 ford maverick
    I'm taking it it's not a stock 302 block nor close to a 302 haha
  2. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    With out a pile of money in that mtr. at 900 to the crank,do not plan on it lasting very long.build a 600hp 408 & never look back,cheaper & will last longer & in a 2800lb car with the right parts,9s all day.Plus this could be accomplished on a street car with some planning,which ever route you take,have fun & put every chevy on the trailer you can when you get to the trk.
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    true dat! better longevity and cheaper to build a 9.5" height block making 600 horses with a 300 shot than a 8.2" height block making 500 with a 400 shot.
    Of course, one could still build an 8.2" block to 600 horsepower and hit it with the smaller 300 shot.. but the valvetrain cost will start getting exponentially more expensive and lifespan will start to rapidly decrease in the process. Tons of ways to skin that cat but some will cost you more initially and over the long run than others, is all.
  4. airford1
    airford1 Member
    San Dimas, Ca
    Its a 460 stock block with 10.4 compression and old Blue Thunder heads. Have over 400 passes on it now and expect another 400 passes before I open it up. Shift at 6000 rpm and hit the traps at 6200 rpm all on pump gas.
    JoeB likes this.
  5. JHodges
    JHodges thumper
    Dora Alabama
    With a 2nd fuel system and a good nitrous tuneup I don't see any problems spraying a 100-150 shot
  6. airford1
    airford1 Member
    San Dimas, Ca
    Seriously, for your effort just spend the time and money to supercharge or turbo and in the long run you will be on the track/street having fun. ....... Cheaper in the long run, but what does an Old Drag Racer know.
  7. bmcdaniel
    Yep, it does get to be a PITA getting the bottle refilled all the time. I used to get about 8 good runs from a 10 lb bottle, then have to fill it up for $40, so basically it cost me $5 every time I hit the button. And that was 15 years ago, I have no idea what nitrous goes for nowadays.
