No accessory position on switch.
Discussion in 'General Maverick/Comet' started by ike72com, Oct 10, 2020.
  1. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    I think that guy owned a few of my cars before I got them
    ike72com likes this.
  2. ike72com
    ike72com Member
    Charleston SC
    Sitting behind drivers seat. Pulled switch out several times and reinstalled.
    Neat how it works after studing.
    Barrel must be rotated to allow push pin to collapse. Barrel Slots aligned to groves on colum, Push in and rotate to lock in place.
    Rotate clockwise from lock position to start. "Works great as before"
    Rotate counterclockwise from lock position for accessory. " Not working as before"
    Accessory position is like a steel wall. Aint gonna happen!!!
    Gonna leave it as is for now.
    Hope this post helps others.
    Thanks guys and be safe
  3. Krazy Comet
    So how are you getting cylinder to rotate past the lock position to depress capture pin?
  4. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    Did you look close for that little ridge in the collar? This is EXACTLY what mine did before I ground it down.
  5. ike72com
    ike72com Member
    Charleston SC
    I did noticed that hump. And sure enough it did not ride up that. Got it to ride in other position. Makes sense now!
    I,ll file down some tommorrow. And report back.:thumbs2:
    I threw in towel giving up and yalls making me pick it up to fight on.:tiphat:
    xpsnake likes this.
  6. ike72com
    ike72com Member
    Charleston SC
    In my hand it works fine. Stick it in and problems.
    I,ll do what XPsnake suggests.
  7. xpsnake
    xpsnake Bruce
    Awesome! I used a little rounded "ball" tip engraving bit on my dremel and just smoothed it until it worked. A dab of graphite and I haven't had a problem since.
  8. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Just for giggles since you are a pro at pulling it now, you could take it out and use a screw driver to verify the internal parts are working properly.
  9. lastchance
    lastchance Member
    Hingham , Massachusetts
    The gear the lock goes into is a tooth off.Reset the gear.
  10. Krazy Comet
    So once assembled how do you remove it again? Lock should not be free until rotated past ACC.
  11. ike72com
    ike72com Member
    Charleston SC
    After installing switch. I,m able to remove switch by turning to crank position "clockwise" and jiggle out.
    I dont even have to remove steering wheel to press pin to release.
    Taking out should not be that easy.
  12. ike72com
    ike72com Member
    Charleston SC
    Well done team:clap::clap::tiphat:
    I have accessory position now.
    After screwing around with this thing as you all suggested. WITH STILL NO LUCK!!!
    I dug and found an extra switch I mistakenly bought months ago.
    Stuck in!!! and i got no problem!!! Accessory position works as suppose to.
    The switch that works is obvious of better quality.
    Krazy Comet and 71gold like this.
  13. Krazy Comet
    Something in the column assembly is preventing lock pin from extending once turned to ACC...
    Congratulations.
    What you are calling switch is just the lock, actual switch is mounted on top of column, under dash.
    mojo and ike72com like this.
  14. ike72com
    ike72com Member
    Charleston SC
    And you are absolutely correct. Your earlier post lead me to examine operation of pin closely.
    That release pin was hanging. Not extending fulling out. Explains why i was able to jiggle it out.
    :beerchug: to all!!!
  15. xpsnake
    xpsnake Bruce
    Yesssssssssss! Good work. Disappointing it wasn't that ridge though, haha!
    Krazy Comet and ike72com like this.
