No electrical power anywhere
Discussion in 'Technical' started by Hairy W Bush, Mar 26, 2013.
  1. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    that could be possible. I want to take the other part off so I don't have to kill my self trying to soder the other wire on. are you typing on a phone??
    as for what you were saying before that, the clip must have been off long before I got the car because there's no clip on the bolt or the black box anymore. I wish I had a working camera to show you what I'm working with right now.
  2. Hairy W Bush
    Hairy W Bush Member
    Georgia
    i just borrowed a camera off my neighbor so I can show you guys what I'm talking about for the fuse box and the condition of the wire (which I believe is sufficient to carry power)
  3. jusgotamaverick
    jusgotamaverick Member
    washington dc
    75 ford maverick 4.1 250 six
    Without the clip the fuse box nd firewall connector should come apart.....nd yes i am on my phone ill try to post a pic 2mrrw
  4. Hairy W Bush
    Hairy W Bush Member
    Georgia
    Here are the pictures:
      File size:
      556.7 KB
      38
      File size:
      519.8 KB
      39
      File size:
      1,023.4 KB
  5. simple man
    simple man Member
    Bunnell,Florida
    In your third pic you are showing that your fuse link is burned out! :)
  6. Hairy W Bush
    Hairy W Bush Member
    Georgia
    is it? like I said I've never had to deal with one, but I thought they burned a little more than that. also, was the hole I tested on the one further down there to test the line?
  7. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    yep that's what i think as well..like i stated mine was loose and i had this issue before..a wiggle and a push in and i was back in business...fuel pump kicked on :)
    just seen your pics there...don't think that thing should be roasted...may want to replace it.
  8. Hairy W Bush
    Hairy W Bush Member
    Georgia
    I'll get that back together and try, but I need to finish the other wire. can you tell what I need to do to get the fuse box plug off? that guy said there's a clip but I don't see it.
  9. doncomfort
    chillicothe oh
    Yeah but now that I see the fusible link Im thinking MAYBE a wire got pinched when the box was reinstalled and hooking up the battery fried the link. :huh:
  10. Hairy W Bush
    Hairy W Bush Member
    Georgia
    don't those things keep burning until you disconnect the battery?
  11. doncomfort
    chillicothe oh
    I think they blow like a fuse..... POOF!
  12. Hairy W Bush
    Hairy W Bush Member
    Georgia
    alright so then it's down to the box and that wire for now. do you see anything on that box that has to be moved for me to disconnect it?
  13. doncomfort
    chillicothe oh
    Its been years since I fooled with mine. All I remember was it sucked!
  14. Hairy W Bush
    Hairy W Bush Member
    Georgia
    bumping this thread and hopefully I can get this resolved here...
    i get no power to the fuse box (thick yellow wire).
    I replaced both fusible links on that yellow wire that powers the fuse box, but I still measure 0 volts at the plug end on the firewall. And before you think my wiring is bad, I tested it just after my splice and I have under 13 volts.
    I just checked a wiring diagram and there's no more fusible links on that line.
    edit: just went looking some more and the plug to the regulator is has yet ANOTHER BS rig job. red wire came apart and the yellow wire it's crimped with is messed up. I bet this has something to do with it. anyone know what that small canister thing is on the shock tower? is that a capacitor?
  15. MSmithPDX
    MSmithPDX Member
    Portland, OR
    its a capacitor, its purpose is to filter engine noise oit of the electrical system for your radio. If you have a modern radio you don't need it.
