No oil pressure
Discussion in 'Technical' started by 289, Sep 22, 2013.
  1. olerodder
    olerodder Member
    NorCal
    Sorry, sometimes I react to quickly..............if you think something is not right you should always question at least one of more people.
  2. John Holden
    John Holden Member
    NJ
    At least I'm not going crazy! And I use the same type bearing that you do.
  3. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    olerodder, how much does a kit like that cost? if i ever have to open up the front again i might replace the stock plate with that.
  4. olerodder
    olerodder Member
    NorCal
    I think last year when I bought another one it $105, but they really do their job...............you just need to be sure to set forward thrust of the cam to within .004/.008 window.
  5. John Holden
    John Holden Member
    NJ
    The better timing sets come with the Torrington bearings.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    He said silicone, not "silicon". :cool:
  7. olerodder
    olerodder Member
    NorCal
    Guess I was thinking of "Wafers"..................not gasket material:rolleyes:
  8. Krazy Comet
    Chips inside a engine is a bad thing, but I expect it may happen one day...
  9. simple man
    simple man Member
    Bunnell,Florida
    They've already done it to transmissions:naughty:Just wait! :16suspect
  10. olerodder
    olerodder Member
    NorCal
    You took the words right out of my mouth:burnout:
