No power to A/C compressor
Discussion in 'Technical' started by charlie9049, Oct 21, 2016.
Tags:
  1. charlie9049
    charlie9049 Lorenzo
    Navarre Florida
    1972 Comet
    I have a 1974 Maverick factory a/c with a new style compressor. Sometimes it will get a full 12 volts to the compressor and then it only sends less voltage and the clutch won't kick on. What could be causing this?
  2. 71gold
    sounds like a loose connection....
  3. 71Mavrk
    71Mavrk Member
    Nevada
    Your AC thermostatic switch may be going bad or, as Frank said, the connection may be bad. Could also be a broken wire. See what voltage you get at the switch.
    Micah
  4. Krazy Comet
    Dismal Swamp
    Anything loose/corroded in circuit from fuse panel to the compressor can cause voltage drop... As already stated if switch contacts are burned or connection loose that could do it...
  5. mojo
    I have/had a similiar problem. I wired around my thermo. sw temporarily so my comp. runs constantly. Bypass the sw and see what happens! If that don't work, problem somewhere else.
