No response from "Technical" Forum, so maybe "Cosmetic"--installing bucket seats
Discussion in 'Cosmetic' started by scooper77515, Jun 25, 2005.
  1. Earl Branham
    Lugoff, SC
    I had to use an 18" piece of 1/4" angle iron to make the mounts, as the Honda runners mounted to the side of the seat frame, not under it. I removed the runners, drilled and mounted the angle iron to the frame, and then had to massage the angle to accept the Maverick seat rails. I then had to level and set the seat height. It took a while, but I am pleased with the results. Good luck!
    p.s. You could use a piece of 3/16" aluminum angle, and probably get better results. Iron is very heavy, and hard to work with. I am going to change mine out when I get the chance. eb
