No reverse !!!! WTH!
Discussion in 'Cosmetic' started by Mav_Max1972, Apr 12, 2019.
Tags:
  1. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    And I wouldn’t recommend putting anything in the trans that’s a “quick fix”
  2. Krazy Comet
    Dismal Swamp
    Yeah, the servo piston is easy to change, BUT one really needs to drop valve body to insure strut that connects with band hasn't slipped out of place. Broken band can be determined with adjustment. If adjusting bolt doesn't snug up in approx 2-3 turns, either it's busted or the aforementioned struit is out of place.
    Miracles in a can rarely fix older automatics and rarely any newer one with sudden problems, mostly they clean sticking valves, solenoids etc. One could toss just about any snake juice in a Windstar automatic and make at least some improvement. A friend fixed one with Lucas.
    Mav_Max1972 likes this.
  3. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    I didn’t think I would be getting such great advise from a Cometier over some of theses Mavicans. So thanks.
  4. 71gold
    I don't think is a broken problem to be changing parts or opening up transmission. it was driven 4 days earlier, sounds like something stuck to me. that is why I recommended the ...Lubegard ATF Protectant
  5. Mav_Max1972
    Mav_Max1972 Member
    California
    1972 Ford Maverick
    No worries I understand but some like my who doesn’t know crap about transmissions rather just take it to a shop
  6. ike72com
    ike72com Member
    Charleston SC
    I know this is an old post. I'm interested in knowing if you ever figured out what failed. Please update.
    I'm currently refreshing an old transmission so in trans learning mode once again.
    To add if i remembered. It was the ears on my band that broke years ago in mustang. Found the piece in my pan.
