No spark...need someone else's point of view.
Discussion in 'Technical' started by scooper77515, Nov 14, 2014.
  1. 71gold
    I've ran the pertronix style system in my Harleys, VWs, 6 cyl Chevy van and my Ford Maverick 6/8 cyl. motors.
    Hummmm...my 52' 8N Ford tractor may be next....:yup:
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Endorsement from personal experience. I purchased a factory duraspark unit from this guy scott@reincarnation-automotive.com. After giving him some details about the vehicle he sent me one curved for my application. I already had an old duraspark setup in the car but the dist was giving me problems. Holy freakin' cow batman!, a properly curved distributor makes a big difference in the old seat of the pants meter. Of course you can recurve it yourself from articles on the net, but I needed a rebuilt distributor anyway.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Would you be comfortable posting the specs that it was re-curved to?
    I'm just curious.
  4. jasonwthompson
    Carrollton TX
    What he sent was the amount of vacuum advance at the distributor up to 2900 rpm, at which the distributor is fully advanced. If you add your timing advance to the distributor (vacuum) advance, you will get the total advance for the engine. My timing is set to about 10 degrees BTDC, so at 2900 rpm the total advance would be 29 degrees. From what Scott said, he uses a Sun machine with the specs you provide to set it up. I was skeptical of the difference it would make, but I could feel the difference in the car. I cannot recall all the specs he requested, but I do remember sending the engine size, cam specs, transmission type, rear end gearing, possibly the tire size along with other info.
    1000 rpm 2 degrees
    1500 rpm 6 degrees
    2000 rpm 12 degrees
    2500 rpm 16 degrees
    2900 rpm 19 degrees
  5. Krazy Comet
    Vacuum advance only operates at part throttle and is no use at WOT...
    Specs are for mechanical advance which consists of a pair of weights and springs in the base of dist...
  6. 71gold
    will this fit Scoopers tractor...:huh:
    Crazy Larry likes this.
  7. scooper77515
    Depending on what engine I put in, it might...:evilsmile:
