No Spark
Discussion in 'Technical' started by boogiedad, Feb 26, 2008.
  1. myselfandiamho
    myselfandiamho Member
    hayden al
    1969.5 2dr 6cyl auto
    boogiedad cant tell about a condenser by looking. replace it with the points and you will be ok. bad condenser can cause your new points to burn up.
  2. 71gold
    i have bought ...bad, new condensers...keep the old one...
    ...:Handshake...
  3. cougar18
    cougar18 Member
    north ca
    74 maverick/71 comet
    it sounds like you need to do a coil test first to find out what part of the system is out
    with everything hooked up take a test light from ground to + of coil with key on you should have power now go to - side and crank you sould have blinking light.if on the + side you have no power its ingnition, wires,fuse... ok if you have power there but not blinking on - side problem is points,condentor,or dissy if both side check out then you have prob in coil,cap,rotor,wires,plugs..... hope this will help
  4. boogiedad
    boogiedad Future V8 Mav owner
    Pt. Orchard, Wa
    70' 2dr Maverick
    Weeee, changed out the points and condenser today and threw some gas down the carb and she started...didn't run though...thnx for the tips. Next up, fuel pump and alternator :bananaman
  5. boogiedad
    Pt. Orchard, Wa
    70' 2dr Maverick
    Ok,
    New alternator and fuel pump installed. Gapped the points to .25 which the book calls for. Verified that the new pump is pumping fuel by disconnecting fuel line at the filter on the carb and got fuel feedback. Pouring gas down the carb produces an attempt to run but the choke is hard to work with and there appears to be laquering in the carb so I am guessing the next thing to replace is the carb :cry:. Should I replace it w/another carter 1bbl which is on it or go w/a holley?
  6. Mavman72
    Try cleaning it first,dont condemn the carb untill you know for sure its the source of your problems.May just be the old crummy gas in the float bowl causing the no start.
  7. boogiedad
    Pt. Orchard, Wa
    70' 2dr Maverick
    Am looking at the fact that I have replaced almost everything under the hood with new parts, why not just go ahead and replace the carb too? lol. Will post more pics soon as I get new batteries for the cam.
  8. Mavman72
    Havent you spent enough yet??:rofl2: Just tryin to save you some cash if I can.Of course if you have some extra $$$ I could use some:DThis stuff adds up fast dont it??
  9. 71gold
    my carb. man said he had rather (rebuild) the old carb. rather than try to tune a reman. one. :yup:
    ...Frank...
    (hi mavman 72) :rofl2:
  10. Mavman72
    Hi Frank!! got some extra$$ laying around??? I like cookies too.:p
  11. boogiedad
    Pt. Orchard, Wa
    70' 2dr Maverick
    damn right it all adds up quick. Have spent almost as much in new parts as I did for the car to start with. Spent 450 for the car and somewhere in the neighborhood of 250 or so in parts
