No start trouble
Discussion in 'Technical' started by JosephBrand, Nov 23, 2020.
  1. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
    I can't get my maverick to start. We got it started by putting gas in the carb at first. We replaced the fuel filter and pump. Also the ignition coil. Now it cranks but won't turn over. Only place I touch wires was by the coil. I believe I wired the coil connector correctly.
  2. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
    I can't get my 1975 250 straight 6 maverick to start. We got it started by putting gas in the carb at first. We replaced the fuel filter and pump. Also the ignition coil. Now it cranks but won't turn over. Only place I touched wires was by the coil. I believe I wired the coil connector correctly. We have all the drum brake stuff in my closet that cost like 100 or 2. We replaced the coil, coil connector, fuel pump, fuel filter, starter solenoid, and voltage regulator.
  3. 71gold
    "We have all the drum brake stuff in my closet."
    and what parts would this be. I wouldn't put off installing or at least comparing them to the parts on the car. sometimes it's a trick to get the correct brake parts the first time ordering.
    mojo likes this.
  4. JosephBrand
    JosephBrand Member
    Munford TN
    1975 maverick
    we have already compared them. they are correct but we are trying to get it started before doing the brakes. weare going to try another coil this weekend and if that doesn't work we will replace the icm.
    71gold likes this.
