I was driving the mav last weekend and my turn singles quit working. I have checked all the bulbs and grounds. all the lights work, brakes,parking and driving and side marker. Fuse is good and I replaced the flasher, I didn't know witch flasher was turn and emergency so I moved the new one to each spot and checked to see if they worked. Emergency flashers won't work either. Do you think the turn single switch is bad ?
Where is a good place to buy a turn single switch ? are the mustang switches the same ? Nevermind, I see Melvin's has them for $75.00
When you hit your brakes the power to the brake lights goes up the column to the turn signal switch and back out again - your switch also sends the turn signal power out those same wires - brake lights still work/signals don't - probably the switch
