Noob needs tire recommendations
Discussion in 'New Members Forum' started by Matt Pistritto, Apr 8, 2015.
  1. Matt Pistritto
    Matt Pistritto Member
    1977 Mercury Comet
    can you upload a picture of your 155/80r/15s when you put them on? those look really skinny, i was gonna do 225/70r/14 in front and 255/60R/15s in the back, because i like how the hotrocks red comet looks. can you upload a picture of the tires when theyre on?
  2. JoeB
    JoeB Member
    Stowe, PA
    71 Maverick, 72 Comet GT
    Yeah the fronts are going to be on the skinny side...th wheels are going to be a 15 x 5"...I would shoot a pic but my front wheels won't be in till August and I dont want to put the new rears thru any extra abuse in the mean time...the rears are 15x8" with 4.5 backspace...doing it again I would go with a 4.0" backspace
  3. Matt Pistritto
    1977 Mercury Comet
    s0 y0u have 14 inch rims in the front and 15 inch rims in the back? thanks for your info everyone! i love your setup & ialready found the tires i want in the sizes you have now I just need rims
  4. junrai
    junrai Member
    rancho cordova ca
    you could take that one tire off and get a used replacement then drive the car to the tire shop
    WITH the boy I never thought about joebs point.
    and by the way WOW what a great mom gonna buy the boy NEW wheels AND tires WOW!
  5. Matt Pistritto
    1977 Mercury Comet
    Hotrock,
    I used the tire sizes you said above ( which my son loves the look of your comet), getting ready to order them and it says it wont fit his vehicle?? Is this because yours in a 72 and his a 77??
    Annie
  6. ford71
    ford71 Member
    Spokane Washington
    1971 Ford Maverick
    I have BFG's and rune 205 70 14 on front and 235 70 15 on the back. Fills up the rear nicely.
  7. Hotrock
    Munroe Falls, Ohio
    Mom,
    I assume you must be ordering the tires on the internet with an automated selection system which will not recognize anything other than standard/stock tire and wheel fitment? The tire sizes I suggested will fit your son's Comet. There is no difference concerning tire and wheel size between the vehicle years.
    Where you will find a problem is with the rear wheels. My wheel and tire combination fit nicely with just the right amount of space between the springs, frame, inner wheel sheet metal and fender lips with no rubbing. My rear steel wheels which are 15" X 8" wide with a 4.25" back spacing are a Chrysler application I purchased; including the mounted and balanced tires through Summit Racing. The selection of wheels with a 4.25" back spacing is limited. I can provide you the part number of the wheels if you are interested. If you do not like the look of the steel wheels, you may be able to use a wheel with a 4" back spacing but do not deviate any further.
    There are a lot of options for a front wheel and tire combination using 225 70R 14s. My front wheels are old rusted 1960s Keystone mag's that my son murdered out. You can duplicate this combination easily.
    Let me know if you have any further questions.
  8. mojo
    I have 14" tires all around on stock OE 500series wheels. My tire dealer had no problem getting them "that was 4 1/2yrs ago". Since then I ordered a new spare "last year", frm Tirerack.com. If your car has worn front springs there is a possibility of 225s rubbing fender wells. I originally had the tire shop order 205-70*14 for the front and when he put the car on the ground they immediately rubbed. I didn't have worn out springs; previous owner had removed coils material from practically new springs. I left the shop w/ 195-70's he happen to have in stock. They are presently on the car thou I have replaced front springs a few years ago. If you order tires online and mount & put them on car -- they will most likely not exchange them --- If ur going that route, make sure u know the exchange/return policy. Someone, in earlier post mentioned taking the car to local dealer and try some tires -- gud suggestion IMO.
  9. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    I went with P235/60r14 if you can find them. These were my first replacement s. Now all new aluminum slot mags on 15 'rims. Front 215/70R15 and rears are P 275/R15s purchased from Summit Racing.
  10. mojo
    275's rears work ok, w/o any tire rubbing?
  11. schroensr
    1975 Mercury Comet
    No tire rubbing yet. My car is in complete restoration mode right now. Just redone the engine an working on the front cowl assembly.
  12. schroensr
    1975 Mercury Comet
  13. schroensr
    1975 Mercury Comet
    The 302
  14. schroensr
    1975 Mercury Comet
  15. Craig Selvey
    Mom....you really need to take your car to the tire store and figure out what will work. Going off what you read on the internet could lead to a lot of money spent for stuff that will not fit.
    Shorty likes this.
