Numbers matching ? 76 Comet
Discussion in 'General Maverick/Comet' started by SilverStreak, Sep 8, 2017.
  1. SilverStreak
    SilverStreak Member
    Montreal
    76 Comet 4D - 6K30T - Silver/Blue - no power anything
    Hi,
    To what extent do "numbers match" on a 76 Comet? The only place I see my VIN is on the metal tag riveted to the dash. The data plate is no longer on the car. I guess I can have one reproduced.
    Is any part of the VIN stamped anywhere else on the car?
    Thanks
  2. Acornridgeman
    Wisconsin
    The VIN is stamped into the inner fender top, on drivers side (sometimes passenger too). You need to unbolt and remove the fender to see it. This is a rust prone spot on these cars. Hopefully it is still intact.
    A partial VIN is stamped into the engine block and transmission too. And some cars have a buck tag attached to the radiator support. Not many, but some.
  3. gonzoayres
    gonzoayres Member
    Honolulu Hawaii
    1973 Ford Maverick 250cid 6cyl automatic 2 door
    by any chance, do you know where the partial vin is located on the engine block?
  4. 71gold
    I thought I saw it under the car somewhere...:huh:
  5. Krazy Comet
    Dismal Swamp
    Useful information. :disagree:
    On 6cyl engines there is a machined pad or two on sides of block, the partial VIN will be stamped there... It's also stamped on top side of the C4 automatics, usually just behind where the bellhousing mates to main case. Std trans it's approx same location, usually by one of the mounting ears...
    Your car as example, the partial VIN will have 30T omitted.
  6. Acornridgeman
    Wisconsin
    And, they got pretty sloppy with the stampings. Finding an extra digit or being off by a couple is not uncommon.
    Paul Masson likes this.
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Numbers matching is pretty irrelevant on Mavericks and Comets.
  8. Krazy Comet
    Dismal Swamp
    Mine has a 8 in the VIN & 8 under the hood.. Ain't that a match??
    Crazy Larry likes this.
  9. Paul Masson
    1971 Grabber
    Mine had two partial VIN's stamped in EACH fender apron...
  10. Krazy Comet
    Dismal Swamp
    The voided VIN was stamped by equipment designed for this operation... The actual VIN is hand stamped(note fonts are different), results in oddly spaced & angled numerals..
  11. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    The V-8's had the VIN stamped on the back of the block on the top pad where it meets the trans. I have the original 302/c-4 for my 71 GT.
