Oil accumulator
Discussion in 'Drag Racing' started by Falcenac, Oct 30, 2019.
  1. Falcenac
    Falcenac Member
    Sechelt B.C. Canada
    1969.5 Maverick 71 Comet G.T. 76 Comet 4 door 61 Falcon x2 60 Frontenac
    I have had oil starvation issues looking at an accusump set up with the electric pressure switch, any input from someone using a similar system would be appreciated.
  2. bb466
    bb466 Member
    west virginia
    72 Mav
    I've had the Moroso system on my car for over ten yrs. Wouldn't race without it. My car used to wheelie badly with a front sump pan. Took out several crankshafts. Installed the system , problem went away. I like the oil pressure prelube before starting the engine. My engine guy said after 300 runs the bearings and crank looked brand new!
  3. Falcenac
    Falcenac Member
    Sechelt B.C. Canada
    Thanks that's the info I was looking for , I have also wiped out a couple of crankshafts. I have a system on order to go in with a fresh motor and better oil pan should be good this time.
