Oil leak at intake manifold
Discussion in 'Technical' started by 1974fordmaverik, Nov 23, 2010.
  1. Boosha
    Boosha Built to run hard
    Buckeye State
    69.5 Maverick,1964.5 Mustang,1966 T-Bird
    sent you a pm
  2. baddad457
    Could be coming from the PCV spacer under the carb. If the PCV is sucking a lot of oil, that'll end up possibly coming out where you describe.
  3. rthomas771
    The PCV is not part of the pollution control. It is needed to let the engine breath. Without the PCV you will push oil at the weakest link. Hook the PCV back up and it will stop leaking.
  4. justin has a 74
    kentucky
    You did what? You have it connected to the intake right?:16suspect
  5. Bryant
    a long shot, but possible is the intake manifold has a crack and the oil in the lifter valley is able to get through the crack. my first thought is the pcv valve hose is leaking oil at the base of the carb but am unsure if there is still a pcv valve on the car still. you should have a pcv valve it only helps and doesnt hurt.
  6. Streamliner
    Streamliner Member
    Make sure the PVC valve or valve cover vents aren't plugged up...If so, crankcase pressure could be building up and it'll find any way out it can
  7. 1974fordmaverik
    1974fordmaverik Member
    huber heights Ohio
    74 Maverick
    okay but when i have the pcv on the intake it makes the car have like a huge miss in it. there is some kind of miss in it but when i put the pcv line on it does it alot worse. do you know what that could be
  8. rthomas771
    Re-adjust your carburetor and timimg with the PCV hooked up.
  9. 1974fordmaverik
    huber heights Ohio
    74 Maverick
    i have done that multiple times
  10. Bryant
    is the hose on the pcv valve soft and plyable or dried out and hard?
