Oil pan Clearance
Discussion in 'Technical' started by chase d. reed, Jul 8, 2015.
  1. chase d. reed
    chase d. reed Member
    74 comet
    I'm swapping out the old 302 out of my comet with a 351c out of a ranchero, will the oil pan clear or will I have to replace it with a different one?
  2. mav1970
    When my car was in it's stock configuration, my Cleveland pan cleared everything just fine :tiphat:
  3. Craig Selvey
    You will find that this is a little bit of a "job".....not a simple bolt in.
  4. mav1970
    It is a tight fitting engine - cutting back the spring towers is the way to go :thumbs2:
  5. baddad457
    Hell, that's the way to go even with a 302 ! :biglaugh:
