Oil Pan Drop
Discussion in 'Technical' started by MaverickPDX, Apr 7, 2020.
  1. MaverickPDX
    MaverickPDX Member
    Portland, OR
    1977 Ford Maverick, 250 i6, 1991 Ford Econoline
    Hey folks, I'm trying to remove the oil pan of my '77 Mav and give it a thorough cleaning. The starter is one of the things that needs to be removed in order to do so. Unfortunately, I've lost my Chilton's guide and now I'm not sure what I'm looking at... it looks like the starter is attached by two bolts, plus one connecting it to an electrical source. After draining the crankcase and the taking out the swaybar, I disconnected those bolts and am now trying to remove the starter. It looks like the back of the starter is sealed to a gasket somewhere towards the rear main seal(?). I tried prying it off but the gasket started oozing. Figured I should consult the forum before I damage something.
    My questions are: what is the back of the starter attached to, and how do I remove it safely?
    Thanks people.
  2. 71gold
    starter has no gasket...two bolts and the wires is all.
    TeeEl likes this.
  3. MaverickPDX
    MaverickPDX Member
    Portland, OR
    Thank you. It looks like the starter is a newer replacement. Unfortunately, the person who installed it might have used gasket sealer to hold it in place...
  4. Krazy Comet
    Dismal Swamp
    LOL the chance gasket sealer alone is going to hold a starter, zero & none. No doubt there are bolts in it, in addition to a bit of goo smeared around.
  5. MaverickPDX
    MaverickPDX Member
    Portland, OR
    I removed the two nuts holding the starter in place. There was another one towards the top of the mount, but the starter didn't budge after I removed that one either. If there's yet another bolt, I'm totally baffled as to where it could be. Hope that Chilton's guide turns up...
    And, yep, I'm aware that this doesn't make sense and probably sounds a bit silly. This should be a very simple task. But, some people find joy in things they aren't very good at, and for me, this is just one of those things :rofl2:
    Russell likes this.
  6. yellow75
    Tillamook Oregon
    Three bolts total not including electrical hook up. Try leaving the electrical hooked up and turn it over with the key (pull coil wire so it wont start) If starter is not able to turn it over then use a pry bar and turn it over by hand, bendix may have the gear stuck out and engaged in flew plate. You may just have to get angry at it and pry hard
    MaverickPDX and Dan Starnes like this.
  7. MaverickPDX
    MaverickPDX Member
    Portland, OR
    I started the car without the coil plugged in, put it in neutral, disconnected the starter from the electrical, doused the starter with PB Blaster and pried with a chisel. The damned thing popped off. Victory.
    Everything looked fine inside both the flywheel housing and the starter, but I guess some things just get stuck sometimes.
