oil pan hitting stabilizer arm.
Discussion in 'New Members Forum' started by toastalo, Feb 1, 2011.
  1. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Way too much off set in those mounts. Only about 1/4" off set on Maverick mounts. Autokrafters list the frame stands in their catalog, don't know if they actually carry them or not, but you can look at a pic and see the difference in them and the ones you have.
  2. blugene
  3. rayzorsharp
    Back the the oil pan issue, I believe trucks use a larger capacity pan, possibly 6-7 qrt? Could this be part of your problem? I agree, those frame stands are not correct for these cars and I dont believe they will work.
  4. ford84stepside
    Berry Alabama
    Yep, look at the ones Blugene posted and compare to yours, nowhere near alike. That's a good price on those on eBay, if they stay that low....
  5. Joe Dirt
    Front sump truck pan is a 6 qt pan it should fit in a maverick with no issues the sump is just a tad larger.
    I believe his whole problem is in his mounts.
  6. fordman57
    fordman57 Member
    Hinton WV
    71 Comet
    oil pan
    I know that the 6qt truck pan will not work, did that did not work
  7. toastalo
    toastalo Member
    mississippi
    1973 Comet
    Hey thanks for the advice, ill see what I can do about the mounts and I have gotten a front sump oil pan from a 74 LTD stock with a 351w, and it seems to be working great... The shock towers are seeming to be another problem. The special order headers are hitting .Previous owner beat and banged them pretty badly, how hard is it to replace them?
  8. toastalo
    toastalo Member
    mississippi
    1973 Comet
    Does anyone happen to have a picture of their headers in place or out? The driver side hits shock tower on front header bendback and passenger hits on second header after bend back just past back bolt that holds top a frame...
  9. Joe Dirt
    sorry had a pic of 302 headers
  10. blugene
    If they are banged bad then wait on the install and shave the towers. I wish I woulda found this site before I put my motor in cause my towers are banged also..looks like crap. Here are some posts that contain info to some others issues. It's a search of "shaved towers".
    http://mmb.maverick.to/search.php?searchid=3139447
  11. toastalo
    toastalo Member
    mississippi
    1973 Comet
    ok i have a few pictures of where the headers are hitting, Ive got the headers on, transmission mounted and floating, waiting on frame stands, doing what i can do. Maybe with a better look somebody can get me back on the right track. img_0263_original.jpg img_0264_original.jpg img_0265_original.jpg img_0266_original.jpg img_0267_original.jpg img_0270_original.jpg
  12. toastalo
    toastalo Member
    mississippi
    1973 Comet
    first three pictures are driver side and other three are passenger side. once again im stumped...
  13. oztrucking63
    oztrucking63 New Member
    roach, mo 65787
    72 maverick grabber 401 9 inch brodix heads dart block strange frontend wilwood disc brakes 4 piston vented slotted rotors pro flow. 73 mercury comet 408 winsor rhs heads all forged eagle rotator 9inch 3.70s disc rakes c4 reverse manual pro flow nos.
    i would wait on my motor mount stands and get my engine @trans where it should be and from the looks of your shock towers would consider shaving them
  14. justin has a 74
    kentucky
    :eek::49:
    Poor.... poor shocktowers.
    :wrongforum:
  15. blugene
    That's what I'm sayin..
    Looks as bad as mine. The headers look closer than mine at the steering box. Does the pitman hit the tube? Looks like it's right next to it.. Watch out when turning it for the first time. Have someone watching cause it will bend the tube easily.
