Oil pressure gauge and plastic hose to sending unit
Discussion in 'Technical' started by scooper77515, Feb 1, 2007.
  1. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I have had cooper on PINKY for the last 6 years....ain't got any vibrations though :rofl:
    *$hit...I just jinxed myself for sure :(
  2. scooper77515
    Dan, how accurate does that electric one work...
    I am not looking for rocket science here, just approximate values, within 2-5 psi of accurate. If it falls below 10psi, I will pull over and cut the engine anyway.
    With wire, it either works, or it doesnt. No leaks, drips, cracks, etc. Plus, smaller amounts of "stuff" coming through my firewall.
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    No idea on accuraccy ... it reads 0 when engine is off ... and moves between 45 and 70 depending on engine speed and hot or cold ... I would say it's definitely working ... the electric temp guage is right on for sure ... I have a 180 degree thermostat installed and it opens right when my gauge hits 180 ...
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Personally, I don't trust electric senders.
    Just me, I know they often do work.
    However, they don't work a lot more often than mechanical gauges don't work.
    Here is what I have learned from some bad experiences:
    Copper is okay.
    Steel or braided is better.
    Plastic SUX!
    FWIW: NEVER USE AN AMP GAUGE.
    The reason I say that is that the worst experience I ever had with gauges involved both an amp gauge and a plastic oil hose.
    The amp gauge shorted, common with an amp gauge, and the extreme spark generated burned through the plastic oil gauge line right next door to it. The oil then sprayed all over the inside of my car while traveling in traffic. The spark turned to fire which spread through my gauges, dash, wiring, and some of the oil burned.
    So that left me trying to get off a crowded 6 lane road in Memphis with my dash on fire and oil soaking my interior.
    NO MORE AMP GAUGES
    NO MORE PLASTIC LINE
    I have had other plastic lines break and other amp gauges burn, but this incident was the worst.
    Some say copper is bad, but I have never had it break... :huh:
  5. don graham
    got copper in mine. never had a problem. :huh:
  6. blugene
    Search for "Triple cannon gauges". Those are electric and I will be working on them this weekend.
  7. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    tubing
    copper works fine. Just have to make sure you havea gommet where it goes thru the firewall so it doesn't rub a hole in the tubing. Proplr don't like it because it's hard to bend. :(
  8. 71gold
    ...bottom left is oil press....:yup:
  9. scooper77515
    Sounds good enough for me:thumbs2:
  10. scooper77515
    Like these?
    http://www.jegs.com/webapp/wcs/stores/servlet/product2_10001_10002_752285_-1
    I have seen them in some of the newer cars, and I like them.
    But for this car, I really want to fabricate a more stock looking dash with all the gauges in the instrument panel in front of me, and not on the pillar, hoseclamped to the steering column, or stuck in the radio hole (like mine are now, on the column and in the hole).
    Very old pic of mine.
  11. stmanser
    Davenport, Iowa
    yup.. nylon tube is illegal to use on all drag strips... if they see it, they will tell you to leave
    also need 12" of rubber fuel lilne MAXIMUM on any car on the track
  12. 72Maverick351
    72Maverick351 Member
    Salem, NH
    1972 Maverick - 351w
    I originally installed an Autometer electric gauge, after 3 sending units failed I went to a mechanical gauge with copper tubing, it's been working great with no problems and no leaks, just make sure you use thread sealer on the fittings.
  13. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I have used copper in the past without any problems, but I can see where if it was unsupported it might vibrate and break. A few simple rubber lined adel clamps to the shock towers should insulate it enough, but make sure you leave a coil near the engine to give it a little flex when the engine moves so it won't break there...
  14. ratio411
    ratio411 Member
    Pensacola
    Ya know, back in the day... ;)
    I remember when mechanical oil pressure gauges came with a roll of copper tube!
    Plastic tube is a relatively new thing.
  15. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    I have always run copper. The plastic hardens with age and will break. Had that happen twice. Braided line would be great, but ya gotta have a larger hole in the firewall to run it through and the right length.
    Why would an electric guage be a bad idea? Mechanical guages have not be used on new cars in decades.
