Oil
Discussion in 'General Maverick/Comet' started by SamsDad, Aug 26, 2014.
  1. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    zinc concentration doesnt really mean much when it also has roughtly same amount of more calcium deterngents in it...these two substances counteract each other, this subject gets tricky with flat tappet guys
    best bet(safe route) for flat tappet guys after proper cam/lifter breakin is to use either AMSoil Z-rod or Joe Gibbs Driven HR-2/HR-4 oils
    but some people are having luck running SM/SN-GF-5 dexious oils with flat tappets(seems to be stock to mild cams), so cam lift/duration and open/closed spring pressures may be the real culprit in cam/lifter failures more then lack or zinc or too much calcium concentration
  2. garrettmuir1227
    garrettmuir1227 (Almost) Certified to Work on Your Porsche
    Temecula,CA
    1974 Mercury Comet (small bumper Mav converted) 2009 Mustang Bullitt #5834
    Pennzoil Platinum. again i recommend it. and its smells exactly like popcorn :rofl2:
  3. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    I have run Mobil One for over 20 years and highly recommend it.
  4. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    And it doesn't leave any unpopped kernels......
    garrettmuir1227 likes this.
  5. SamsDad
    SamsDad Member
    Little Rock, Ar
    1973 LDO turned Grabber Clone
    Loving the Demon now that everything is tuned well, only thing I would recommend if you were going to look at one is look at the 750 CFM......It says it is great for highly modified small block V8's, I have ask in another thread the definition of "highly modified" small block V8
  6. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Yeah stought small blocks and mild big blocks started having fuel distribution issues with the 625..which is why they now have a 750
    As.for highly modified smallblock..I'd say something with 500 and up crank horsepower
  7. TrotMaverick
    TrotMaverick Tyler Trotter
    Gaston, Oregon
    1972 Ford Maverick Grabber, 2016 Chevy Sonic
    How do you think the platinum would do for a 200 - 6? Never ran synthetic in it but looking for a good recommended oil to change it out tomorrow. Also, any filter recommendations for the 200, I've always used the FRAM basic in the past.
    Thanks!
  8. 73curtis
    73curtis Member
    ohio
    I like the look of the motorcraft filter and I just use whatever oil is cheapest 10 30 or 10 40 in my 200
    TrotMaverick likes this.
  9. Krazy Comet
    Dismal Swamp
    Assuming not rebuilt in the last 10 years or so use either 10W-30 or 10W-40 High Milage oil, synthetic not necessary...
    After being in the engine for approx a year(that accumulated less than 100mi), the 10W-40 Quaker State Defy has stopped the drip from rear main in my 428... It'd had a small leak so long I don't remember when it didn't drip... Hasn't marked it's spot since before I installed the power steering back in March...
    Use a Motorcraft FL-1A filter, unless you're springing for some HIGH $$$ filter they are as good as you get for $3.50 or so...
  10. TrotMaverick
    Gaston, Oregon
    Not necessarily looking to spend high $$$...just want to get the performance to match my engine abilities. The engine is stock so nothing fancy is needed, unless it will increase the performance on an old motor! thanks!
  11. 71Mavrk
    71Mavrk Member
    Nevada
    I recently changed the oil on my '63 Jag. 2,700 miles on the motor. I was running 20/50 conventional Castrol. I got some free Royal Purple 5/30 synthetic from Summit. Thought what the hell. It smoked so badly that after 50 miles I had to dump nearly 8 qts and buy some Castrol. No more smoke.
    This guys page on oil is interesting:
    https://540ratblog.wordpress.com/2013/06/20/motor-oil-wear-test-ranking/
    Micah
  12. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    I would recommend you run a Non-Synthetic Oil FIRST for another 1000 or 2000 miles and get some miles on
    the engine ... THEN .... do the synthetic . We broke in several engines in this manner and they all perform great..
    We recently drove a 70 Maverick and a 74 Comet on a 3500 mile HRPT after a break-in with Non-Synthetic Valvoline Oil then changed to Synthetic Oil for the Tour and didn't use a quart of oil from start to finish . JMO
    Cometized
    (Chip)
  13. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
  14. Krazy Comet
    Dismal Swamp
    as a FYI
    SamsDad has zero to do with posts #22 onward that pertain to a stock 200...
    Yes there should have been a new thread started...
  15. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    Oil selection and lubricating qualities has nothing to do with cubic inch.
