ok lets build a 351 w FOR THE STREET
Discussion in 'General Maverick/Comet' started by classic ccg, Feb 3, 2012.
  1. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Pretty sure this isn't a roller block...
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    The iron Sr heads are a sweet deal for a budget racer.....and are a good head regardless. Do some port work and they really shinei
  3. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Big F'ning deal. Look up "retro-fit hydraulic roller" sometime.
    A lone voice in the wilderness............. :beerchug:
  4. facelessnumber
    Memphis, TN
    '71 Grabber
    Look up civility some time. Is this really necessary? Where does this negative, condescending and caustic attitude you convey so consistently come from?
    But back to the topic at hand, do you really think everything you listed, including those retrofit lifters, fits his stated budget?
  5. bmcdaniel
    And did he consider that the stroker crank will have to be balanced plus the Chinese cranks often have problems with bearing journals that are tapered or over-/under-sized. Can't just throw together a stroker kit, everything has to be checked and straightened out. IMO the AFR185s are just right for a 351 but too small for a stroker. The World SRs give a lot of room to work with for the money.
  6. classic ccg
    ringgold GA
    72 maverick
    idk maybe he is haveing a bad day
    :huh: but thank you guy im still going to be looking a the gt40p bc of my money now and just go 30 over
  7. danchmp
    danchmp Member
    Albertville,AL
    1973 grabber
    Always remember when ur on a budget. It cost more to buy stuff twice. If you buy gt40ps and go threw them you are spending at least 400 with a new set of springs. A new set of BETTER heads are not that much more. Save up a little more money and do it once.
  8. classic ccg
    ringgold GA
    72 maverick
    ok mpw that i have to go w 30 over and a good set of heads idk what now but you guys have gave me some good sites to look at but now im looking at how much horsepower can a t5 transmission handle but cant find a good a answer. but do i need to w a 9in or will my 8 in hold up this is some info on my car and this may help you guy help me
    i have a 8in four lug.
    also it will be on street tires not drags
    it will stay mostly on the street but some week end fun :drive:
    maybe this will help
    and this is the Clutches im looking at
    http://www.summitracing.com/parts/ZZZ-MU48-1/
    http://www.summitracing.com/parts/ZZZ-F3-48/
  9. bmcdaniel
    Depends what T5 your talking about. There are different versions. My T5Z is rated at 330 lb-ft. You can put an Astro or Gforce kit in it and double the rating. On street tires you'll probably spin the tires before you hurt the trans.
  10. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
    I don't deal well with those so full of misinformation.
    Then build a budget style shortblock but give it a good set of heads and decent camshaft. Don't scrimp on the parts that make power. GT40P heads on even a stock 351 will be a phenominal turd.
  11. facelessnumber
    Memphis, TN
    '71 Grabber
    I'm not misinforming anybody. I knew about the retrofit roller lifters. Rollerizing the engine never entered my mind because I was paying attention when he said his budget is $2500.
  12. quickshift
    quickshift Member
    Ontario Canada
    71 comet/84 cougar
    I know I'm new here but that $2500 budget will go a LOT farther on a 347 than on a 351 of ANY stroke....even stock.
  13. classic ccg
    ringgold GA
    72 maverick
    5 speed out if a 89 mustang
  14. ShadowMaster
    The ShadowLands
    1969 1/2 Maverick
    Really? Your 1 1/2" tubes are inadequate for a 302 with any decent camshaft. Spreading that style of misinformation bugs me. There are headers out there that fit and have good tube size. Just have to look for them.
    No it won't.
  15. classic ccg
    ringgold GA
    72 maverick
    im just going to run stock w afm heds and just go 30 over and thats it but thank you guy for the info and the help
