One Piece Front Clip!
Discussion in 'Drag Racing' started by valleyracer, Jan 20, 2010.
  1. Millersrevenge
    Millersrevenge Ricks Hero
    canada
    So I ended up having to rebuild the whole corner and a good chuck of the floor. Wasnt happy with how the frame was to the floor and now was the time to do it. I think I will most likely end up doing the same thing on the other side...find out pretty soon. That square in the corner is the 2x3 the cage is going to mount too.
  2. Millersrevenge
    canada
    All I know is that this looks EXPENSIVE!!:dancing:(y)
  3. olerodder
    olerodder Member
    NorCal
    Does the rust extend into the rocker panel?
  4. Dave B
    It's into the torque box....lots of fun.
  5. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    We had water coming in on this side so I knew that was a problem side!
    Now is the time to get it fixed right...lots of fun friggin Ford weekend...lol
  6. Millersrevenge
    canada
    Drivers side was like this too. Got the torque box done on this side and the 2x3 in for the cage. Also had to replace some steel in the rocker. Think I might just change the whole passenger floor. fkn fords:)
  7. olerodder
    olerodder Member
    NorCal
    Send more pictures of your work..........................it never stops, it seems the deeper you probe, the more you find to do.............
    IMHO
  8. Millersrevenge
    canada
    Got this side done. Will take a pic inside for you tomorrow.
  9. Millersrevenge
    canada
    Started on the front section of the cage.
  10. olerodder
    olerodder Member
    NorCal
    Looking really good, keep the pictures coming.
  11. Millersrevenge
    canada
    This should tighten her up a bit. Strut towers are really solid now.
  12. Dave B
    It's amazing how loose/soft these cars are. That should do wonders.
    While your at it, you should cut the side impact beams out of the doors...
  13. Millersrevenge
    canada
    Done.(y)
  14. Dave B
    Sweet!!! :tiphat:
  15. Millersrevenge
    canada
    Floors are done, cage is done, dash bar and column brace is in for the new steering column thats going in.
    Going to start building the new dash in the morning.
