One Wire and the IDIOT light
Discussion in 'Technical' started by Scotty P, Mar 14, 2007.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    Summit box just came in. It does have the "prongs" like in Ricks picture above. It also came with a pigtail to use in case "the volt meter does not register on initial start-up" whatever that means! I t says I can wire the other end to the indicator lamp also. I don't think I will as I am doing this to eliminate wires..
  2. Blk70mav
    Blk70mav Member
    Galt, CA
    What part number or brand did you buy from Summit? I have been debating on buying the Summit Racing Brand 100 Amp Alternator for my Maverick. I am tired of my 60 Amp not charging my battery.
  3. Scotty P
    Scotty P Member
    santa rosa, ca
    Sum-810302
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I have a 'one wire GM' that has the battery going to the back post like in the pic.
    However, it has the blades too. They are just covered with a black plastic plug.
    Makes it look flat on the outside, but is obviously removeable to expose the blades. I have done it.
  5. scooper77515
    Good to know that the Summit one-wires have that option also.
  6. bmcdaniel
    Hmmm, next time I take mine off I'll have to check it out closer for a cover.
  7. rayzorsharp
    The black plastic cover is what makes it work as a one wire unit. It actually makes it excite the internal regulator to start it charging. If you take the plug out, I don't believe it will charge at all. This type of alternator setup actually has to have a small amount of rpm (probably 1500 or so) to get it started charging. If you start your engine and never race it up over idle, they will not charge at all. That's the way all of the old GM 1-wire marine alternators were made...and this is the same alternator that has been used for over 25 years or so.
  8. bmcdaniel
    So the cover actually has some electrical connections associated with it?
  9. rayzorsharp
    Evidently so...the old marine alternators simply had a metal connector that just slipped over the 2 blades. The 2 blades are coming straight out of the internal regulator.
  10. Scotty P
    Scotty P Member
    santa rosa, ca
    Glad I idle at 1600 rpms then Ha Ha
  11. rayzorsharp
    Sorry, I didn't mean that it has to remain running that fast to keep charging. It only has to rev up one time to excite the regulator and it will remain charging until the engine is shut off.
  12. Scotty P
    Scotty P Member
    santa rosa, ca
    I know what you meant, I couldn't resist!
  13. rayzorsharp
    :naughty: Bad boy
