Only starts with starter fluid, need advice
Discussion in 'Technical' started by rag9836, Jun 6, 2010.
  1. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Shoot a burst of compressed air through the line toward the tank. Don't just keep holing pressure on it or you might blow something like a tank seam. Just pressurize, hold a sec, then release a few times. Probably the sock filter on the pickup is stopped up. It should just blow off into the tank.
  2. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    take gas cap off!!!
  3. rag9836
    rag9836 1972 Comet, 67K
    Riverside, CA
    Comet
    It was the fuel pump, she's running now.
    I've got a small gas leak at the carb....going to have to tap it, the bolt's stripped.
    So close to getting her on the road.
    Thanks for all of your help guys!
  4. maverick75
    It you need any small parts let me know i have a bunch of maverick/comet stuff just laying around (y)
  5. 71gold
    what part are you having to repair? some things screw into another thing that screws into another thing. maybe you can replace one or the other of them things.
    Frank...:yup:
  6. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Rag
    Before you get to far ahead of your self CHECK and replace ALL rubber hoses on fuel lines ( one under the drivers door and the one at the sending unit ) CLEAN OUT the fuel tank ( after all the yrs. sitting the left over gas in tank has turn into slug . and will screw up the rest of the fuel system )
    good luck with your car Jay
  7. rag9836
    Riverside, CA
    Comet
    The screw that is stripped is the lower left one to the accelerator pump cover.
    I've replaced all the rubber hoses in the fuel system. Filled the tank with gas and then pumped it out....it wasn't bad at all, I think the tank was dry when it was last started.
  8. rag9836
    Riverside, CA
    Comet
    After tapping the bolt hole, the gasket is still leaking.
    I am going to replace the gasket, but....
    Any adivce on 4 barrel carbs that will line up correclty without having to change the intake or do any mods? I am a complete newb....thanks for the advice.
  9. 71gold
    at the least you will have to buy an ...adapter...(Mr Gasket) :Handshake
