Opinions on These Wheel/Tire Combo Pics?
Discussion in 'General Maverick/Comet' started by silver70, Dec 6, 2018.
  1. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    This first picture looks like the Mav has 14 inch wheels because of the wheel well clearance. Anyone else agree?
    This Mav has 245/60R15 in the rear and 225/60R15 up front on 15x8's:
    I really like the stance in the first picture. I don't know what's doin' it for me, but I just like it. However, I picked up a set of 15x8 Magnum 500's a few weeks ago and I'm now conflicted because I see what the second pic looks like with the 15" wheels and, while it's not a bad stance by any means, it's just not quite hittin' home with me. I want more of a '60's factory muscle stance and that's what I kinda see in the first pic. Not such a heavy rake.
    I used to run big/littles but I'm moving away from that to something more practical. Probably the same size tire all around. I'm thinking some BFG Radial TA 235/60R15's which have a slightly wider tread than Cooper Cobra's and others. I want something similar to the tire size of the Boss 302's, but I believe they ran 15x7 wheels. That changes the tire's sidewall "belly" profile which is why I want the slightly wider BFG's for my 15x8's. I dunno…..
    Questions:
    1.) Do the wheels in the first pic look like 14's?
    2.) What do you think of the second pic with 15" wheels? Like the stance more or less than the first pic?
    3.) Backspacing and offset aside, what is the "general consensus" of the largest width tire we can typically fit in the back without tubbing/suspension mods?
    Thanks guys.
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    You picked the size I was going to recommend so it must be right if we agree!:thumbs2:
    silver70 likes this.
  3. Krazy Comet
    Vs difference in tire size, the first picture looks more over sprung to me.
  4. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
    It looks like the wheels might be the same diameter.
    The tires on the orange car are taller.
    I think the rake of the orange car is exaggerated by the reflection on the floor.
    It looks like they are both sitting tall. That's A cool straight line look.
  5. Hotrock
    Munroe Falls, Ohio
    I'm of the belief both sets of tires and wheels are about the same dimension. The difference in rake is due to the front of the orange car being lower than the front of the green car. Compare the location of the rear wheel centers with the lower portion of the front quarters of both cars, Notice the lower front quarters of both cars are at the bottom of wheel center.
    Now compare the lower edge of the front fenders on both cars. The green car's fender edge is at lower wheel center while that of the orange car is below wheel center.
    My opinion, both cars sit too high front and back.
    If you want the 60s factory muscle stance, both these cars have it. If you want the 60s day-two stance both cars need to sit higher in the front with Cragar wheels all around. Much wider Cragars in the rear with a set of huge Mickey Thompson Sportsman Pro meats extending beyond the wheel well lip. `66 and `67 GTOs owners made that day-two look famous!!!!
    I cannot seam to find a picture on the net of any above described day two cars. Where is a day-two photo when you need one?
    Good luck with your project!
    silver70, Krazy Comet and Shorty like this.
  6. z28th1s
    Lynchburg, VA
    The green car looks like a 4x4. As said earlier both cars sit too high front and back.
    An 8 inch inch wheel is pretty wide for the front.
    silver70 and Krazy Comet like this.
  7. Craig Selvey
    I think the tires are the same size. The RWL tires on the green car just make them seem different.
  8. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    Seems most believe both vehicles have comparable wheels/tires. I agree the front of the green Mav is over-sprung. I remember I had a buddy with a '72 Grabber in Calypso Coral with black/yellow stripes. He was running slot mags similar to the Ansen Sprint. I loved the stance of his vehicle. Same tire size all the way around. I just never bothered to inspect them closely to find out tire and wheel size. I fell into the big-n-little trend there for a while. Now, 12 years after I parked my Mav I find my tastes have completely changed. I also used to really like the modern metallic base/clears with toned-down subtle colors. Now, I'm all about single-stage in bright solid colors that used to be found on rides in the 60's and 70's. Interesting what getting older does to a person's perspective.
    Thanks for the feedback guys. Good points made.
  9. Vinchez78
    Vinchez78 Member
    Columbus GA
    1973 mercury comet
    I like the first Pic, same size all around but not the center caps, I prefer the red ones, but it's high up, if it was lowered a bit, it'd be perfect! I want a set of these for my 73 comet soon!
  10. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    I am running 215-60x15s in the front and 255-60x15s on the back all on 15x7 wheels. with no clearance problems. Anything larger than that and you will probably have rubbing issues. I like the Magnums, but I will take Cragar SS's all day long.
    Lee "THE MAV" Richart
    Hippylong likes this.
