Out of gas!
Discussion in 'Technical' started by whitson, Dec 6, 2016.
  1. whitson
    whitson Member
    1974 maverick
    1974 with a 200ci motor. Has been sitting awhile. Gas gauge doesn't work. Ran out of gas and put just enough in to get to the gas station. Filled it up and only held 9 gallons. Any thoughts ?
  2. 71gold
    It didn't run out of gas...:huh:
  3. Krazy Comet
    Either you have a really big dent in bottom of tank or there is a issue with the pickup...
  4. mav1970
    Could the pump have shut off automatically before the tank was actually filled?
  5. krelboyne
    krelboyne Remember
    Salem, Oregon
    Could be plugged fuel filter and/or fuel pick up sock is gummed up.
    If it has been sitting for ages with fuel in the tank, there is varnish every where in the fuel system. Worst case you will need a thorough cleaning / treatment of the fuel tank. When you remove the fuel sending unit, it will likely either have a defective float, or be crudded up.
  6. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    The gas pump probably turned off prematurely. Happens to mine all the time with these newer pumps. Try a different station, or pumping slower.
  7. whitson
    whitson Member
    1974 maverick
    No, kept trying till it spilled out.
  8. whitson
    whitson Member
    1974 maverick
    No, this scenario has happened twice.
  9. whitson
    whitson Member
    1974 maverick
    Filter is new, should I start with sending unit ?
  10. 71gold
    if the tank had 10-11 gals. of gas in it, it ain't the sending unit.
    the sending unit may be the reason your gas gauge doesn't work.
  11. 71Mavrk
    71Mavrk Member
    Nevada
    Maybe part of the pick-up tube has rusted away leaving a hole that it cannot get any suction further down the tube. Replace the sender unit.
    Micah
    Krazy Comet likes this.
  12. Krazy Comet
    And why I stated in my first post it could be pickup...
    71Mavrk likes this.
  13. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Ran into this same thing several times on marine applications.
