Overheating issue
Discussion in 'General Maverick/Comet' started by Vomit_Comet, Oct 21, 2016.
  1. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Oh, OK. That was going to be the next question.
  2. Vomit_Comet
    Vomit_Comet Member
    Orange City, Florida
    1972 Mercury Comet
    I guess my next step is to just leak down test it like Krazy Comet has said. I really suspect that it's a head gasket issue. Guess I'll make a run to harbor freight and grab a tester.
  3. Maverick Dude
    Yes, sounds like it. The collapsing hose was probably just a side issue. Let us know what you find.
    MD
  4. Krazy Comet
    Dismal Swamp
    A V belt system can only operate in one direction...
  5. 71gold
    "hose collapse" with a "blown head gasket" is an oxymoron...:yup:
  6. Vomit_Comet
    Vomit_Comet Member
    1972 Mercury Comet
    That's what I'm thinking and with the compression test results being fine I don't know what else it could be? I didn't get a chance to do the leak down today but I'll do it tomorrow if I have some free time just to know for
    Sure.
  7. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hey VC:
    Question ?? Did the overheating issue commence AFTER you replaced the head gasket ?? Which side did you
    replace , Drivers Side , or Passenger? WHEN did you change the head gasket ? Lemmeno please.
    Cometized
    (Chip)
  8. Vomit_Comet
    Vomit_Comet Member
    1972 Mercury Comet
    Hey, Chip.
    The drivers side head gasket was blown in between cylinder 5/6 and starting to go again between 7/8 on the drivers side. I replaced both sides as you're never supposed to just replace one. It blew because the idiot before me put the gasket on backwards blocking the main cooling port to the head. The over heating issue stopped at that point. Now(2 years later) it's back. Although this overheating issue is different than when the headgasket blew.
  9. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi Nick:
    How long has it been since you put the Radiator in ? Even when something is NEW .. there is always a possibility
    of a problem .. Just Say'n ..
    Cometized
    (Chip)
  10. Vomit_Comet
    Vomit_Comet Member
    1972 Mercury Comet
    New radiator and fan were put in together 3-4 days ago. I flushed the old radiator and tried that one again and it did the same thing.
  11. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    BUMMER !!
    Chip
  12. 71gold
    did anything flush out?
  13. Vomit_Comet
    Vomit_Comet Member
    1972 Mercury Comet
    So I think I got it figured out unfortunately... I compression tested the car one more time and I have two cylinders at 150- 160 and two are around 120-125ish constitanly and those are the same cylinders it blew on last time so I think that gaskets starting to go again...
  14. 71gold
    if so you may need some machine (mill) work on the heads...:yup:
  15. modmav
    modmav Member
    Jamestown ND
    Yes if thats the case you may have warped head, what type/brand gaskets you use?
