Overheating issues in hot weather
Discussion in 'General Maverick/Comet' started by Ajdelrio, Jul 10, 2018.
  1. Ajdelrio
    Ajdelrio Member
    Los Angeles
    1970 Maverick/1972 Chevelle/1998 Mustang Cobra/2011 BMW 335I
    Stock 70 mav I6 200, New water pump, 160 thermostat, Chinese ebay aluminum radiator, stant rad cap, overflow tank, stock fan w/o shroud, no AC, timing set to factory specs.
    The car is a daily driver, 30 miles to and from work, usually around 70 mph on the freeway. The car usually runs a constant 160 degrees.
    last few days the weather has been is the 100-110 range and the car started overheating on the open freeway. The car seems to slowly cool down once I jump off the freeway and hit surface streets. It also drops to 160 if I spray the rad w/water
    Not sure if this is the norm for an older maverick or if I can do anything to help keep it running cooler.
  2. mojo
    Are you running 50/50 anti-freeze mix? What do you consider overheating? Is it boiling over? I think the shroud will make a difference w/ heating issue.
  3. Ajdelrio
    Ajdelrio Member
    Los Angeles
    yes 50/50 mix, gets up to about 230, has gone as high as 250 with water spewing out of the cap
  4. Acornridgeman
    Wisconsin
    I have a '70 - 200 with stock radiator and it runs fine in the heat of summer.
    Barring some heavy scale or blockage inside the engine, my guess is the ebay radiator not transferring heat very well.
    Here is a great read on the often hyped aluminum radiators out there.
    http://www.speedcooling.com/3_Row_Versus_4_Row_Comparison.html
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Did you put the thermostat in backwards? I did that once when I was a kid.
  6. mojo
    Yea, that's hot. Have you checked lower rad hose too see if it may be collapsing? If so, that may be the cause. Lower should have a spring to keep from collapsing.
    CaptainComet likes this.
  7. Ajdelrio
    Ajdelrio Member
    Los Angeles
    Haven't checked the hose yet, it is fairly new though, has that metal spring in it
  8. Krazy Comet
    Three words... Shroud, Shroud, Shroud.
    jasonwthompson and Crazy Larry like this.
  9. Ajdelrio
    Ajdelrio Member
    Los Angeles
    Yes thats where I'm probably going with this, along with a new flex fan
  10. 71gold
    no flex fan...:tsk:
  11. Ajdelrio
    Ajdelrio Member
    Los Angeles
    Any recommendations on the fan...?
  12. 71gold
    about any E-fan should cool that 200...
  13. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Keep the stock fan, a flex fan is a waste of money, and if you get one for free, it is a waste of time to put it on.
    Crazy Larry and Krazy Comet like this.
  14. 71gold
    did we get this thing cooled down?
  15. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Don't go with a ' Flex-Fax ' they are DANGEROUS .. and are prone to come apart with the airborne blades
    and do terrible things. I lost a friend here in Florida when he was revving the engine of his 302 with the hood
    up .. the fan disintegrated and one of the blades hit him in the neck severing his jugular vein .. He bled out before
    he could receive aid and was gone within minutes. His wife still has their Grabber and we still keep in touch..
    Not a ' war story' .. this really did happen and I advise you to get a fan OTHER THAN a flex !! A shroud and a
    good Electric Fan is a great option and will really aid the cooling of the engine. Just my take on the fan .
    Cometized
    (Chip)
