Overheating issues in hot weather
Discussion in 'General Maverick/Comet' started by Ajdelrio, Jul 10, 2018.
  1. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    I would recommend a higher temperature thermostat, like about a 190 or 195. It won't hurt your engine a bit and the greater the difference between the engine temperature and the outside temperature the more heat you can transfer. Basic thermodynamics. An electric fan is good too.
    Lee "THE MAV" Richart
  2. Krazy Comet
    Basic thermodynamics or not, unless current thermostat is defective it'll still overheat on a hotter stat, probably more so.
    mojo likes this.
  3. stumanchu
    stumanchu Stuart
    Portland, OR
    If spraying water onto the radiator cools it right down, then I imagine anything that increases the radiators task of shedding heat would help. I also vote for a shroud or a shrouded electric fan.
