overheating problem 1977 comet 302
Discussion in 'New Members Forum' started by nmdinsmore, Mar 22, 2014.
  1. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    Me too - on a 1980 AMC Eagle. When the water pump was replaced, the mechanic put the fan on backwards. The derelict couldn't figure out why the vehicle continued to overheat, even after his repair.
  2. nmdinsmore
    nmdinsmore Member
    california
    1977 mercury comet 302
    So I'm differently thinking it was the water pump. I pulled that sucker was internally messed up.
  3. mojo
    That will cause some overheating issues. Replacing pump shud get the car on the road.
  4. nmdinsmore
    nmdinsmore Member
    california
    so i found out the previous owner did a cheap radiator leakstop stuff from napa, so it explains some of the discoloration. when i pulled off the water pump it had a thick sandy brown stuff inside of it. the bearing on the water pump seemed to be fine but i did run the car for a little while and part of the flow on the waterpump was bone dry like it hadnt ran. ill let you guys know more in a few days when i put the new water pump on. thank youeveryone for the help and opinions on what the problem may be. ill let you guys know if it works thank you.:thumbs2:
  5. 71gold
    :Welcome:...:Handshake
  6. mav1970
    I really hate this stuff because it gets into every part of cooling system :mad:
  7. nmdinsmore
    nmdinsmore Member
    california
    So good news is I got the water pump replaced flushed the system several times and am running water with a prestone radiator and cooling system cleaner
    The car stays at 190-195 now. I'm very happy its running great. I have one more flush to do before I add real coolant not just water and the cleaner. Thank you everyone for the help!!!:dance:
  8. mojo
    Glad to hear you solved that problem. Now it's time to hit the road Jack! :thumbs2:
  9. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
    Where in CA are you located?
  10. nmdinsmore
    nmdinsmore Member
    california
    Close to the most northern part
  11. 71gold
    I know where that's at...don't you live on the left side of the street going in?
  12. nmdinsmore
    nmdinsmore Member
    california
    What do you mean???:drive:
  13. mav1970
    That's just Frank being Frank :rofl2:
  14. 71gold
    ...:thumbs2:...
  15. nmdinsmore
    nmdinsmore Member
    california
    i just wanted to give you guys a good update. ive been driving the car almost daily. i drove it out highway 36 and gave it a true test. the car started to over heat with the good size hills and constant slowing down and speeding up. so i am glad to say i have the heating problem fixed
