Overheating so soon?
Discussion in 'General Maverick/Comet' started by DocRoche, Jan 19, 2017.
  1. Krazy Comet
    Probably a leaking water pump, common problem...
  2. DocRoche
    DocRoche Member
    1973 Ford Maverick
    Went out and checked the fan. Had a slight wiggle to it Which was told might be the pump and bearing. If the pump is leaking is that a gasket or pump and gasket replacement?
  3. mojo
    Pump and gasket! I use plenty of gasket sealer when doing a replacement...
  4. 71gold
    I suggest taking the old pump with you to get the new one...:yup:
    mojo and DocRoche like this.
  5. Krazy Comet
    If surfaces are clean and true, only a small amount of sealer is necessary...
