paint is oxidized!!
Discussion in 'General Maverick/Comet' started by 71351wmav, Mar 9, 2005.
  1. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    Simple. Get a good dual orbital buffer and a collection of foam pads. Meguires is the one I use but there are plenty of options. The important factor is to select a dual orbital buffer. Foam pads go from aggressive cleaning to much softer polishing pads. The color of the pad tells you if it's for aggressive cleaning or polishing and everything in-between. I am able to remove heavy oxidation using Meguires fine cut and medium cut cleaners. You can make the paint look as good as is possible (depending on paint condition) without breaking a sweat. Of course you should finish with a high quality wax or polish. I can make my cars so shiny you would think you were looking at a mirror.
  2. groberts101
    groberts101 Member
    Minneapolis, MN
    I dare you try and beat Maguiers Diamond Cut 2.0 for everything from cutting the oxidized layer and continuing all the way to the final buff stage. The compound changes grit from rather aggressive to ultra fine very quickly and you only change pads for a clean final polish with the same stuff. Works amazing and you can even cut orange peel with it too. As Harley mentiones above, use the correct foam pads, cutting pad and then polishing pad, for the task at hand.
    Caution required on edges and very thin paints though.. this WILL burn through if not careful.
  3. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Wont be hard as theirs heavier cutting polishes then dimond cut 2 some thatll finish better
    Menzura f400 comes to mind
    Scholls s3 is another
    3D HD Adapt wont have that much cut but its the best all around polish ive used so far on various level course foam pads with its AAT
    Heres a comparison chart of polish/compound agressiveness
    Some polishes are SMAT, some are DAT some are both and some 3D HD is AAT
    http://www.autopia.org/forums/paint...d-5-2015-autopia-polish-comparison-chart.html
  4. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    If your polish has DAT ..Deminishing Abraisve Technology, make sure youre completly break them down ..polish will be clear , otherwise you can scour/haze the panel
    If its SMAT you can do as little or many passes needed to achiece your results
    3D AAT same thing as SMAT, just make sure not to use fast movement and youll be well
  5. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
