Pan filled c4 in 72 comet
Discussion in 'Transmissions' started by ike72com, Nov 22, 2019.
  1. ike72com
    ike72com Member
    Charleston SC
    Anyone put c4 pan filled (large bell) in there comet? This is what i'm working on currently. Any clearence problem? Thought i'd ask before go any further.
    Thank you
  2. Krazy Comet
    Should be OK, the AOD bell is approx same size but like AOD, 164T flexplate is required.
    Also the flexplate must match engine balance which changed for '80/'81.
  3. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    thats what im getting ready to put in my 70. A few in the facebook group said they put a pan filled in a 70. The 70 has a smaller tunnel, so if it can take one, the 72 should be fine.
  4. ike72com
    ike72com Member
    Charleston SC
    Thanks for the heads up fellas. I think it'll work as well.
  5. Rasit
    Rasit Member
    SE Pennsylvania
    My 71 has a pan fill. It’s a little tight but really no problem at all.
  6. ike72com
    ike72com Member
    Charleston SC
    Got her in with motor attached today. No problemo at all. Did had work stoppage and had to make run to orielly' for correct transmission mount.
    I'm gonna do a backflip if an old driveshaft i took off my 70 mustang 10 years ago fits.
  7. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    Did you use the double hump transmission cross member to bolt the mount to? The V8 has two bends in it for dual exhaust. The i6 only has one side.
  8. ike72com
    ike72com Member
    Charleston SC
    My comet is a v8 car. Previous owner have dual exhaust installed so probally have double hump.
    If u need a picture id let me know.
