Part Identification/Nut Removal Woes
Discussion in 'Technical' started by MaverickPDX, Oct 17, 2019.
  1. MaverickPDX
    MaverickPDX Member
    Portland, OR
    1977 Ford Maverick, 250 i6, 1991 Ford Econoline
    Hey fellow Maverick/Comet-lovers... I'd like to replace my valve stem seals. To do this, of course, I have to remove some of the stuff above the engine.
    There's a metal tube that goes over the valve cover and links to this thing to the left of the engine, picture attached. What is this? What's it's purpose? If I damage it somehow, will this be hard to replace? My assumption is that it's part of the emissions system, but in spite of browsing these forums and flipping through my trusty Chilton's Guide, I still haven't figured it out.
    Also: that nut that connects the metal tube, is this some kind of weird proprietary size? I'm pretty close to stripping it with a 5/8ths wrench and my 15mm wrench is too small.
    Thanks!!
  2. Doug
    Doug Member
    washington state
    71 maverick grabber
    You need to use a flared nut wrench . Anything else will just round it off then it will be vise grip time . I think it is for fuel vapors ?
  3. Craig Selvey
    That is a vacuum line for the power brakes.
    Replacing valve seals is not necessarily for a novice. It will take some knowledge so one doesn't drop a valve off into the motor.
  4. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    You would be looking for a 19/32" wrench. They do exist, but just not a common size anymore. They sit between the 15mm and the 5/8" wrenches. - Matt
  5. Krazy Comet
    Dismal Swamp
    Actually a 19/32 is all but exactly 15mm(15.081mm), you'll never know difference.
    Eons ago I went with a uncle to buy a set of metric tools so we could work on his VW bug. The Craftsman set we bought had no 15 mm but did include a 19/32".. With that knowledge, I made it a point to know what metric vs std could be used for each other.
    With correct flare nut wrench(in my opinion a absolute necessity) that fitting should break loose easily.
    mvw66gt and BBMS18 like this.
