Passenger side ac compressor brackets?
Discussion in 'General Maverick/Comet' started by jasonwthompson, Apr 3, 2018.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Anyone here with a small block ford and the ac compressor mounted on the passenger side? We will shortly be resurrecting the ac in the Comet with an aftermarket kit and if possible I would prefer the compressor on the same side of the car where the hoses are on the firewall. We have all the factory brackets for the drivers side but I thought it might be a cleaner installation on the passenger side.
  2. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
    The 302 town cars had the compressor on the right.
    jasonwthompson likes this.
  3. mojo
    Where will the alternator be located?
  4. jasonwthompson
    Carrollton TX
    Same side, either above or below the compressor depending on what ac brackets I can find.
  5. mojo
    Interesting. I like to see how you accomplish it - don't believe I have ever seen that setup.
  6. Krazy Comet
    The easiest factory install would probably be to use '86-'91 Crown Vic/Grand Marquis setup(likely same as Town Car)...
    It mounts A/C compressor on upper right with smog pump below... With a little adapting, I'll guess the alt can replace smog pump... Normally the Alt is on driver side with P/S pump below...
    Note this is a serpentine belt setup(actually two) but unlike Mustang, T-Bird etc, uses a std rotation water pump...
  7. NICK DOMINICK
    Burke, Virginia
  8. jasonwthompson
    Carrollton TX
  9. NICK DOMINICK
    Burke, Virginia
    March serpentine system and custom hoses. Classic Auto Air universal system.
  10. NICK DOMINICK
    Burke, Virginia
  11. jasonwthompson
    Carrollton TX
    That is the exact system I was contemplating for the Comet. Are you using factory controls or CAA's controls?
  12. NICK DOMINICK
    Burke, Virginia
    It took some fabricating but I used the factory controls.
    Jerry and jasonwthompson like this.
  13. jasonwthompson
    Carrollton TX
    Awesome, expect I will have to do the same.
  14. mojo
    You going w/ aftermarket AC too? Is your car equipped w/ Factory AC?
  15. jasonwthompson
    Carrollton TX
    It is/was a factory ac car, but I prefer an updated system over gathering and reconditioning parts. All the underhood components are missing and all the interior ones are in need of replacement/restoration.
