Paul Masson's 71 Grabber
Discussion in 'Maverick/Comet Projects' started by Paul Masson, Mar 6, 2013.
  1. Dave B
    That's a lot of grinding! I'm always amazed at the pile of stuff on the floor, I swept up around my car today...
  2. car-nut
    car-nut Glenn
    conn.
    Looking great so far. NIce job with the cowl.
  3. Paul Masson
    1971 Grabber
    There was just as much stuff in my hair and clothes as there was on the floor. I looked like a coal miner when I came in from the garage. Sweeping is a constant activity in my garage.
    Thanks Glenn. Once I have the engine compartment stripped, the cowl cover will come off so I can paint inside it and everything else with POR-15. After that, I'll be able to weld the cowl cover on and never ever have to deal with it again (hopefully).
  4. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    Since you're trying to strip everything it looks like, why not have the car soda blasted? Its pretty cheap, and its all done, hits every crack and corner. Would save you tons of hours, and materials stripping off the paint.
  5. Paul Masson
    1971 Grabber
    Let the Blasting Begin!!
    After struggling with paint removal via the wire wheel and grinder, I consulted with a local Mustang expert and he informed me that the black paint on my engine compartment was likely lacquer. He told me to take lacquer thinner and wipe the paint off with it, then blast the spots that were harder to get to.
    Happily, it worked out pretty good. I pushed the car out today and spent an hour or so wiping and blasting. The firewall is pretty much done and the area rear of the passenger's side shock tower is 90% done. A couple of sunny Saturdays and a note from my wife allowing me to skip taking the kids to dance class, and I'll be in good shape!:D
  6. Steven Harris
    Steven Harris Member
    Looking good.
    I have a picture that looks alot like yours - minus the white background.
  7. Dave B
    Man, you guys don't have much snow...BTW, the car looks awesome!
  8. blugene
    Thursday will be the first year :biglaugh:
  9. Moneymaker 1
    Panama City Florida
    Yeah ya got 3 days to make your deadline! :D
  10. Paul Masson
    1971 Grabber
    Thanks Dave. The snow was higher than the bottom of those windows behind the car a week ago. It got up above 0*C (32*F for those of you below the 49th parallel) for two days last week. The longer the snow stays, the longer I have before I REALLY start to panic about not having the car done for summer...:yup:
    From 2013-03-06:
    I've been "trying" to keep at it, but you know...:D​
    When are you going to stop buying parts cars (Comets) and get a car to build?? j/k :rofl2:
  11. John W
    John W Member
    Walkerton Ontario Canada
    1932 Ford Roadster Hot Rod 1977 Maverick
    Makes me tired just looking at your pictures and remembering how many times I had to blow my nose when grinding all that "stuff" in my car. Primer will make it look much better. A lot of work but well worth it when finished.
  12. Paul Masson
    1971 Grabber
    Still Blasting...
    I managed to squeeze a few hours in with my car today. I am still blasting the engine compartment, but I did get some more done.
  13. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    Lookin good!
    You soda blastin?
  14. blugene
    That driver corner always seems to be a spot that gets the least attention.. And it looks like a good sunny day to get things done. Got cold here so AGAIN my Comet waits.
  15. Paul Masson
    1971 Grabber
    Thanks!
    No soda, just using "00" sand at about 90 psi. Going to have to get a bit rougher ( maybe some "01") when I go underneath and in the wheel wells.
