Paul Masson's 71 Grabber
Discussion in 'Maverick/Comet Projects' started by Paul Masson, Mar 6, 2013.
  1. goldnrod
    goldnrod Member
    Fredericton, NB. Canada
    72 comet gt
    I'm about to do my heater core assembly as well, can you post some pictures ? How do you do an air test on the new heater core, what did you use for caps and what pressure should I use ?
    Thanks
  2. blugene
    I been pretty busy lately and didn't have internet for the last two weeks. What you have done looks really good. At your rate you'll be done in a few..years lol.. jk. Perfection by our standards takes time.
    I managed to bring my diff from my shop and placed it under the rear two days ago. So I might gain on you hahahaha..
    Paul Masson likes this.
  3. Paul Masson
    1971 Grabber
    Another little update. Got some more stuff done over the Easter long weekend.
    injectedmav and kboldin like this.
  4. kboldin
    Santee, CA.
    Looking Great!!!
  5. Paul Masson
    1971 Grabber
    Thanks Kevin! :Handshake:
  6. Craig Selvey
    Make sure you center the steering gear box before you kook it up to the control valve. Made that mistake with mine.
  7. Paul Masson
    1971 Grabber
    Thanks! I'll make sure I do.
  8. Paul Masson
    1971 Grabber
    I have been sandblasting parts, trying to get enough of them ready to open a can of POR-15 without wasting any. Last week, I finally got to spray some POR-15. Two coats of POR-15 Satin Black, followed by a single top coat of Chassis Coat Black.
    Last night, I was able to get my spindles bolted onto the front control arms.
    mercgt73 and biggruss like this.
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    'Looks awesome. That car will never rust again.
  10. Paul Masson
    1971 Grabber
    Thanks Larry! I hope you are right!
  11. Paul Masson
    1971 Grabber
    More Progress last night. I managed to get the front dust shield gaskets made, and the shields, shocks and coils installed up front. I also got to install my new reproduction Autolite solenoid and battery cables. Apologies for the crappy cell phone pictures...
    Krazy Comet and mercgt73 like this.
  12. Krazy Comet
    Niicceeeee!
    You're doin' a great job...
  13. Paul Masson
    1971 Grabber
    Thanks Tom!
  14. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    What did you use to paint your engine compartment?
  15. Paul Masson
    1971 Grabber
    I sand blasted the WHOLE front end of the car. If you don't do this, you MUST follow the preparations using Marine Clean and then Metal Ready.
    Two Coats of POR-15 Semi-Gloss Black:
    http://www.canada-por15.com/merchant.mvc?Screen=PROD&Product_Code=15&Category_Code=POR15
    And ONE top coat of Chassis Coat Black, also made by POR-15.
    http://www.canada-por15.com/merchant.mvc?Screen=PROD&Product_Code=CC&Category_Code=Topcoats
    I thinned them a very small amount with the POR Solvent, and sprayed it. POR-15 must be topcoated, as it is Ultra Violet sensitive.
