Paul Masson's 71 Grabber
Discussion in 'Maverick/Comet Projects' started by Paul Masson, Mar 6, 2013.
  1. Paul Masson
    1971 Grabber
    I picked up a 5-lug rear end a while ago. The price was right. Over the last little while I have managed to get it disassembled, cleaned, painted and new bearings and seals installed. Today was rear disc brake mock-up day!! :D
    Krazy Comet likes this.
  2. mercgt73
    mercgt73 Member
    Looks great! Nice progress.
  3. Krazy Comet
    Dismal Swamp
    Super!!! Keep it up & you'll be riding soon...
    Paul Masson likes this.
  4. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    Your rear end looks nice..... well, you know what I mean :) did you use por 15 for that also? I need to place an order for some.
    Krazy Comet and Paul Masson like this.
  5. Paul Masson
    1971 Grabber
    Thank You for the compliment... I think?? :D
    Yes, I used POR-15 satin, followed by Chassis Coat Black.
    Bad Brad likes this.
  6. Krazy Comet
    Dismal Swamp
    I got elbowed in the ribs last time I said that...
  7. bkcha
    bkcha Member
    Pooler, GA
    71 Gabber
    What are you going to do for an E-brake?
  8. Paul Masson
    1971 Grabber
  9. Krazy Comet
    Dismal Swamp
    Well 60/40 solder would scare the bejeezus out of me(see Paul's link), that's just plan old electrical solder... I resoldered so many cracked/broken connections in TV over the years, I couldn't trust it... I'd think it'd pull apart on first brake application(apparently it doesn't)...
  10. Paul Masson
    1971 Grabber
    Yeah, I'm not very good with soldering. I had my house plumbing converted to PEX, just to be rid of soldering copper. I was going to take them into a welding place in town to have them TIG welded, as per DaveB's suggestion.
    I'm not sure if there are any local places here that would have the tools, etc to crimp new balls onto them either.
  11. mercgt73
    mercgt73 Member
    Cable collar stops are another option.
  12. tody
    tody Member
    cologne, germany
    that's what I used when adapting the stock cables to the loncon versailles rear i used...
  13. Paul Masson
    1971 Grabber
    I think I may have to do some more research on this subject. I was thinking the TIG may be hot enough to make the ends of the cable brittle.
    Thanks for the suggestions everyone!
  14. Paul Masson
    1971 Grabber
    More progress:
    I finished making the hardlines for the rear end. I also managed to get the front brakes done, and even had time to try a rim... I couldn't resist assembling my cooling fan, either.
    biggruss, Krazy Comet and mercgt73 like this.
  15. mercgt73
    mercgt73 Member
    Looks great, Paul! Love those wheels.
