People with Champion Radiators
Discussion in 'Technical' started by mrmalina99, Aug 22, 2012.
  1. John Holden
    John Holden Member
    NJ
    My champion radiator required elongating the mounting holes in the radiator in order to raise it up because the lower hose fitting was hitting the crossmember.
  2. Tannersg1
    Tannersg1 Member
    Classified
    I thought maybe they did but i wasn't sure. Most of the mavericks i have seen racing at a local track all use the Champions and some of them are running high end motors! Guess the extra $200.00 may be out of the budget.
  3. Tannersg1
    Tannersg1 Member
    Classified
    Why not weld up the mounting holes in the core support and re-drill a couple of holes?
  4. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    This is my plan.
  5. John Holden
    John Holden Member
    NJ
    If you're asking me Tanners, it was far more easy to file the aluminum rad
    holes a little than weld and redrill the car rad support.
  6. blugene
    Another option.. Get some 1/2 or 3/4 flat strip from Home Depot. Mount that from side to side and drill into that.. Mount the strips using the existing hardware pushed away.
  7. Tannersg1
    Tannersg1 Member
    Classified
    Thats another option!
  8. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    I like this idea
  9. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    when working on old cars sometimes a die grinder is my best friend so is backyard engineering measure with tape mark it with chalk cut it with torch:hmmm: nothing ever seems to fit like it should nowadays especially when i buy it
  10. mojo
    I have the Champ 3 row #CC339 and it fit the core support w/o any issues. As everyone has stated, the Xmem needed to be notched. The only problem I had was the stock fan shroud was not a direct bolt; that was not critical cuz I was going to elec fan setup. I bought the unit April 2010 and it has worked just fine.
  11. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I think I'd rather modify a radiator to fit the car than modify the car to fit the radiator.
  12. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    How very "backwoods-dirt track"......... :rofl2:
  13. blugene
    Why thank you :D
