Pertronix difference.
Discussion in 'Technical' started by NICK DOMINICK, Mar 13, 2005.
  1. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    I run pertronixs because everything fits in cap, no xtra box and wiring on the fire wall, nice clean look...and it works.
    Jim
  2. MountainMav
    MountainMav Member
    Bozeman, Montana
    72 Maverick 250(soon to be 347)
    I replaced the points in my 250 with a pertronix I unit, and was amazed by the results. I used to replace/file the points regularly to get it to run smooth, but from the moment i put the pertronix in it has started and ran like a dream. Definitely worth it.
  3. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    The duraspark box is ugly, There are a lot of wires, and having repaired fords for a living, the box fails more than you would think. It's a viable option, but those are the reasons I run Pertronix.
  4. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    For a high performance car is the Pertronix as good or not as good as having the MSD box?
  5. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    MSD would beat the petronix in my book
    But a duraspark is just a low dollar MSD basically
    As for being ugly... its a box, big deal. lol
    And for failing... I've only seen one fail before. The one on my 76 F-100 leaked all the crap out of it and still ran for years, I replaced it because i got tired of seeing the leakage, not because it didn't run good
  6. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    Correct me if I am wrong here, but Pertronix only replaces the points. The DSII is a high energy system. Parts are available every place. If you are looking for a more powerful ignition system, then the Pertronix aint it. It is only a replacement for points. It will not improve the ignition like a DSII of MSD.
    I have a DSII sitting on the shelf, just been to lazy to install it. I did install a Pertronix in my son's Chebby and it sure ran smoother.
  7. Maverick73
    Lakeland, FL
    I was reffering to the Pertronix 2 not the Pertronix 1, which is just a points replacement.
  8. hotrodbob
    hotrodbob Member
    Will the Pertronix II make the spark hotter?
  9. Jamie Miles
    Will a tach that works with points work ok with the Pertronix?
  10. bmcdaniel
    Pertronix II doesn't make a hotter spark the way a CD box will by amplifying the energy, but it does provide more coil saturation by increasing dwell time as rpm's increase. So at higher rpm's you will have a stronger spark than what points or the original Pertronix provides. If you're just using it to switch an MSD or HyFire electronic box there's no advantage to having a Pertronix II. A big plus with any electronic switching is increased accurracy, no points bounce, pitted contacts, or worn rubbing block. Set it correctly once and forget it. And if you're running nitrous it's recommended not to use points because of the inaccurate timing and chance for point bounce to drain the coil then not provide a hot enough spark. A points-type tach works fine with Pertronix, at least mine did.
