Pertronix Flame Thrower Drive gear
Discussion in 'Technical' started by Racer_X, Apr 17, 2014.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    so apparently the flame thrower D134600 on summits sight is being advertised with a cast iron gear when it really has a hardened steel gear, just saw a review where a customer blew up his motor because of this misinformation. I have the same distributor in my car but haven't fire it up yet with the new distributor and now I'm glad I haven't. But the question is where can I get a cast iron gear to fit the flame thrower. Waiting to hear back from petronix on this issue. Makes me want to just go back to the Ford DSII set up or points :huh:
  2. baddad457
    Summit Racing sells distributor gears. I would make certain of what gear you have first before ordering another.
  3. mavgrab302
    I called pertronix because I needed a steel gear for my roller 5.0 They told me none of their distributors have a steel gear... They told me all were iron... I ended up buying the summit brand distributor...
  4. 71gold
    pertronix...in a points dist..:thumbs2:
  5. Ronald Hopkins
    Ronald Hopkins Member Supporting Member
    Morristown Tennessee
    1972 Comet GT
    What Frank said.
  6. Moneymaker 1
    Panama City Florida
    Have you confirmed you have the incorrect gear? did ya look at yours?
  7. scooper77515
    Hard to tell the difference if you don't know what to look for.
    My problem was the other direction. I know it is a roller cam, but not sure of the brand and cannot confirm it needs a steel gear. Using one, and hasn't blown up yet.
    Any idea how long it would take before you see some damage on either the cam or the gear?
  8. Racer_X
    North Carolina
    Havent herd back from them yet still waiting. How do you tell the difference between cast and steel gears? Did another search and found another review about the drive gear issue another customer saying its the wrong gear on it for a cast cam.
  9. Moneymaker 1
    Panama City Florida
    I would think there would be casting lines or marks on them, I don't really know.
  10. scooper77515
    Easiest way to tell is cast will be rough like typical non-machined cast iron on the bottom face, which is flat in this picture. This one is bronze, but a hard steel one will be pretty smooth on the bottom, as well.
    Also rough along the sides of the top collar.
  11. Racer_X
    North Carolina
    Ok thanks for the info. Will do a comparison when i get off work.
  12. baddad457
    The steel is machined all over, the cast gear has portions as Scoop said that are rough cast.
  13. Racer_X
    North Carolina
    The gear on the petronix is steel, Is the shaft diameter on the petronix the same as a stock ford distributor?
  14. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I have used 2 different pertronix dizzys in my 1995 roller 302. They are definitely steel. I had over 5000 miles on my first one and gear looked brand new.
  15. mavgrab302
    I must have got an idiot when I called Pretronix, They told me I would have to buy a steel gear because all theirs were cast iron... I really wanted to use one on my 95 roller...
