Phase 1 complete
Discussion in 'General Maverick/Comet' started by diddie, Mar 28, 2010.
  1. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    Here's some pics. of new frame rails. turned out pretty good:dance: 464_original.jpg 457_original.jpg 460_original.jpg 461_original.jpg [​IMG]
  2. maverick75
    Looks good!
    anyway we could see larger pics?
  3. diddie
    diddie Member
    indiana
  4. diddie
    diddie Member
    indiana
    i got it figued out. but thanks!
  5. Jamie Miles
    Having those upper shackle bolts in single shear dosen't seem like a good idea.
  6. diddie
    diddie Member
    indiana
    it's solid their not goin anywhere
  7. lilfarley
    lilfarley Chris Comley
    Central City, Iowa
    should have put them on the inside and tubbed it, but it does look really nice.
  8. diddie
    diddie Member
    indiana
    thought about it but not what i was going for. just a slightly hopped up daily driver (maybe the next one!)
  9. Mavaholic
    Nice work but I have to agree with Jamie. I dont think they're going anywhere either but I'd bet money it will eventually bend.
  10. 71gold
    ...one pothole...:yup:
  11. Craig Selvey
    In Indiana? :huh:
    :D Oh yeah....they are everywhere!!!
  12. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Since he's welded it on both sides of the rail, the bending moment is highly reduced, so it's pretty much so just in single shear, and a piece of steel that size will easily support that shear load.
    Even if it does fail, the rear end is still supported at 3 other locations so it will not be a catastrophic failure.
    From a design and FMECA analysis, I give it my engineering stamp of approval.
    Supporting it with some bracketing would get an even bigger stamp of approval though...
  13. 71gold
    this may be good running in a straight line...not so good when turning and putting a side load on it....maybe bend frame rail.
    i would suggest the...spring mounts be center of frame rail...not to the side...:yup:
  14. 71gold
    being the...rear shackles flex...it's only..."supported"... on two points. the rear shackle will allow side motion...(back and forth)...to cause a failure for sure...
    ...JMO...
  15. PaulS
    Having seen the rear shackels bend on a center supported spring I doubt that the bolt will stand up to use very well. Wlding the bolt on both sides does NOT make it stronger or reduce the bending moment. It does provide stress risers at the spring side of the bolt and make the steel more brittle.
    All in all I would have boxed the support so it took advantage of the shear strength of the bolt rather than depending on the bolt to support the weight of the car in bending mode.
