Picture request....power brake booster fitment
Discussion in 'General Maverick/Comet' started by car-nut, Jun 26, 2011.
  1. mojo
    Ok!! Txs. I know now when I get ready for the upgrade I don't have to go arnd lookin for another pedal/arm.
  2. car-nut
    car-nut Glenn
    conn.
    Thanks to all that have responded to this thread. I have decided that the only way to be certain is to drop the engine in and check for fit. Engineered Components Inc. will let me grab all the different sizes he has so I can determine what I need. I will buy what I need and give him back the others.
  3. carnageX12
    carnageX12 Member
    Summerfield, FL
    1976 Maverick
    Any specific information on that booster; brand, size? The ebay listing you posted earlier has ended and I was interested in it. Also what master cylinder are you using? I appreciate any info you can give.
  4. 55crownvic
    55crownvic Member
    colorado springs
    try this one....... http://www.ebay.com/itm/300562957280?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    It is a 7" single diaphram booster and for a decent price
    My master is for a Maverick with power/front disc's. got it at advance or auto zone, cant remember, think it was around $30
    Just remember, this booster will not "bolt up" to the firewall. New holes need to be drilled and the center hole will need to be made bigger. Aint nothin easy when working on a ford!! LOL
  5. flynbrd
    flynbrd Member
    So that actually clears under the stock manual shock tower brace!!! How much power does that 7" booster have? I'm running disk all the way around. Hmm wonder if the push pin will work with my explorer master cylinder. Currently I have the master from a 77 maverick installed working great but I want to run the export bracket :huh:
  6. 55crownvic
    55crownvic Member
    colorado springs
    Yep it all fits under the brace, with about 1/2 inch between the m/c and tower. The braking is excellent, the maverick is not a big heavy car so it works great, with 4-wheel discs I imagin you will stop great!! The push pin on the booster is adjustable or do what I did and get a longer bolt from ACE and make your own push pin
  7. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    I was planning on using this booster; but after buying it, I discovered that the top two mounting studs hit the pedal bracket. Also, the plunger and rod aren't the right length and the studs don't line up with a factory Ford master cylinder. Will have to go with manual discs.
  8. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
  9. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    No reason it wouldn't work, firewall is the same with or without power brakes.
  10. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    Factory PB pedal assembly is supposedly different, due to the angles involved with that set up. Manual brake pedals should be around if you swap. I may do this to my 75, but I have a '70 I can swap the pedals from, that gives me the clearance on the '75 for the 5.0l, and adds PB to the '70 that has the 250 and doesn't need the clearance.
