Points Eliminator Kit Question
Discussion in 'Parts Interchange' started by tonyj71mav, Aug 18, 2018.
  1. tonyj71mav
    tonyj71mav Member
    Upper Marlboro, Maryland
    Has anyone used the Accel 2020 Points Eliminator Kit and if so should the original ground wire that's in the Distributor be removed when setting the Kit up?
    Thanks
  2. baddad457
    Should say what to do in the destructions...………...
  3. Krazy Comet
    Assuming you're referring to the inch long, braided ground for breaker plate, I doubt it matters. The Eliminator has a ground that connects outside dist.
