POLL - Do you degree your new cam?
Discussion in 'Drag Racing' started by Rick Book, Jan 20, 2007.
POLL - Do you degree your new (racing) cam?
  1. Never
    10.8%
  2. Sometimes
    5.4%
  3. Most of the time
    24.3%
  4. Always
    59.5%
  1. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Yes, exactly why it was ground that way.
    My cam from Crane for the 390 had 4º ground into it.
    Helps out bottem end power quite a bit
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    That is deliberate. Comp High Energy and Magnum cams are ground 4 degrees advanced for better low-end. They are not "off" 4-degrees...
  3. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    No....the timing chain/gear sets are off by four degrees. That makes eight degrees.
  4. bmcdaniel
    Always. Only takes a few minutes, just one of the many details of putting together an engine right.
  5. stangclone
    stangclone Member
    ofallon,il
    1972 maverick,1965 mustang
    always!!! to much money to be playing with and it only takes a few minutes.I have had a valve go through a piston because of not doing it :cry: Like shadowmaster said cam was ground at 4 and the timing chain was off 4 witch set me 8 degrees and in a 289 with 12.5 to 1 pistons and a .556 lift cam you don't have that much room
  6. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    When Erson Ground My Cam They They Grind Of The Pin
  7. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Why is it that 5 to 10 minutes of (extra) work can cause such a big debate?
    Who doesn't build a motor to get all they can for the money that was invested?
    Degree your cam! It isn't even as hard as adjusting your rockers but you do adjust your rockers, right.
    As always just my .02(y)
    Bossmav
  8. scooper77515
    I will agree with TL and a couple others...If you are really trying to grab every last point of HP/Torque, I would (like I will on my next cam).
    But on my first and only cam swap so far, I just lined the dots up. It was a mild-moderate cam, and I was just looking for a little boost on my stock rotating assembly.
    Next time I will be looking for power and will most likely degree it...
  9. FredH
    FredH Member
    Seminole, FL
    69.5 Maverick
    I always degree each cam I install. It's really not an option as far as I am concerned.
    As a late great friend of mine used to say, "It's all just s**t in a box until you prove otherwise".
  10. FredH
    FredH Member
    Seminole, FL
    69.5 Maverick
    That's fine until you run into one where the timing chain is off or the cam's dowel pin is not exactly where it needs to be. A friend of mine had to fix a kid's Mustang that would not run after a new set of heads and cam were installed. One of the first things he did was hang a degree wheel on it. Sure enough, the dots were lined up as they should have been but the cam was 17 degrees retarded. Wouldn't run because each exhaust valve was bent.
  11. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I've been lucky. I've always degree'd them, but they've always been spot on. Always check in my opinion, my time is free to me.
  12. Comet155
    Comet155 Member
    Bought the generic Summit degree kit. It's handy to have around.
    So answer: yes, always. It's a good habit to get into.
  13. maverickdvm
    maverickdvm Member
    Michigan
    I am sure some part of this question may be stupid, but I need the info so hopefully it doesn't sound too dumb. Does any company make a crank shaft socket for small block Fords that has the degree wheel attachment? They make them for Chevys, but Jeg's didn't have anything for the Ford. Thank you.
  14. maverickdvm
    maverickdvm Member
    Michigan
    Any suggestions?
  15. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
