POLL: How do you prefer you manual steering maverick or comet?
Discussion in 'General Maverick/Comet' started by kmjwing, Mar 24, 2015.
Do you prefer your manual steer maverick/comet with the manual steer box or with the power steer box
Poll closed Mar 31, 2015.
  1. Manual steering box
    50.0%
  2. power steering box
    50.0%
  1. kmjwing
    kmjwing Member
    mn
    1973 maverick Grabber
    Who of you prefer your manual steering maverick or comet with the manual steer gear box or with the power steer gear box? Just getting an idea of what people are running out there. THANKS ALL!!
  2. kmjwing
    kmjwing Member
    mn
    If any of you feel inclined to post here a pro/con that would be great too. Thanks again folks.
  3. Bryant
    im running the ps box with as much caster ask i can put in the car with 255x40-tires and it steers nicely. i hated the ms box. it was like steering a bus. it took forever to turn the wheel to make any turn.
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Actually, I prefer power steering, but to answer your question; the steering box used for the power-assist has a quicker ratio, which I prefer, although it will be much harder to steer when the car is not moving. Make sure you have a 15-inch steering wheel.
  5. junrai
    junrai Member
    rancho cordova ca
    Ive had both and the handling on the manual seems better but the turning and cruising is much better with power steering.
    the power steering on mine is much easier to turn one way then the other and I understand this is common on our cars where as the manual is tough in either direction
  6. 71gold
    I had manual with PS box. I didn't see any "hard steering"... (14" steering wheel).
    I now have...manual rack n pinion...:drive:...:chirp:.
  7. Krazy Comet
    Fully agreed...
    Then the control valve has a problem, my Comet was same till I rebuilt it...
  8. Hotrock
    Munroe Falls, Ohio
    I experience what Crazy Larry has stated. I'm running manual steering with a power box. Out on the road steering is good. With the car set in place and turning the wheel, not so much.
  9. rthomas771
    Power steer box w/manual everything else. Ain't that hard to turn if rolling at least 3-5 mph
  10. CaptainComet
    Power steering box all the way. Like others have mentioned slow speed is heavy, so I would be sure to have a larger diameter steering wheel. I was running a smaller Grant wheel and it lacked leverage.
  11. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    My wife won't drive it unless it has the power steering.
    Its manual.
  12. Krazy Comet
    And the problem is??
  13. Thomas
    Thomas Member
    Vancouver, BC
    73 maverick
    She says its hard to control. hard to make a turn. I think she just likes it when i have to drive her around.
    I like the manual steering. I have no problems turning it.
    I believe part of the fun with my maverick is to have the car without all the engine accessorizes.
    Radio on and windows down.
  14. Bryant
    i agree with krazy,
    i still dont see the problem!
    my wife wont drive my car because of no power steering or brakes. my car is staying no power steering or brakes!
  15. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Sounds like you need a second Mav with P/S for the wife.
    My car is manual with power box.
