Posi/traction ?
Discussion in 'Parts Interchange' started by elchinelo72, May 23, 2015.
  1. elchinelo72
    elchinelo72 Member
    Los Angeles
    71and 72 ford maverick's
    Does anybody know if there is a positraction for 71/72 maverick?
  2. Krazy Comet
    Never a option for any Maverick...
    Fords Equa-Lock was a option in many '60s/'70s vehicles with 8" rears(also this term was given to 9" before approx '68)... The Ford Traction-Lock is a improved unit used in 9", in the big engined/HP vehicles...
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    But all you gotta do is swap in a 8-inch Traction-Lok differential. It's a bolt-in.
    Krazy Comet likes this.
  4. Krazy Comet
    Agreed..
    Up till a few years ago I had one out of a '67 Falcon station wagon I junked... Since I'd had it laying around for 20 years plus, I let a friend have it to put in his son's '65 Mustang... Yeah wish I had it back...
  5. mav1970
    I know with 9 inch rears, you never know what models you will might find a Traction Lok units in - the one in my 9 inch came out of a 6 cylinder 1970 van with 4.11 gears - I have read where you might find an 8 inch one under junked Mustang II's :)
  6. baddad457
    Best chance of finding a 9" trac-loc is in a Bronco or 4WD pickup.
  7. mav1970
    When we found one in the 6 cylinder van, all we were looking for was a 4.11 gear set for our budget build stock car and the driver/owner didn't have a use for the T-L so it was my gain :thumbs2:
  8. elchinelo72
    elchinelo72 Member
    Los Angeles
    Great guys, I guess is time to go back to God old junk yard and start looking.
  9. Krazy Comet
    AFAIK there were no 8" until the '62 Fairlane introduction...
    I'd guess chances finding a posi 8" in the junk yards these days are maybe 2% of locating a 9", as basically only intermediate & compact models used them... Probably most likely possibility is Granada/Monarch...
  10. baddad457
    Granada's and Monarchs are getting scarce now too. But if you do run across one, keep in mind they had as a option both a disc and a drum brake 9. Seen two 80 Granada's with the drum nine. 80 was the last year of the leaf sprung rear in these cars. Don't forget the Versailles too, they all had disc 9's. And all the above are 28 spline 9's. . Now I mentioned the Bronco's, the big Bronco's had a 31 spline 9 in them, the small Bronco's had 28 spline 9's . 4WD F series pickups could be either spline count. When I went out to get a 9 for my 77 Comet, the first yard I went to had an 81 Bronco with a 31 spline 3.50 Trac-loc 9 under it for $150 (complete rear) I used the chunk out of it and sold the rest of it.
  11. bigblockmav74
    bigblockmav74 Member
    1974 maverick
    I found my 9" with disc brakes and a track lock ( limited slip not posi) in a granada
  12. mav1970
    Mine came out of a 6 cylinder Granada Ghia :thumbs2:
  13. bigblockmav74
    1974 maverick
    This was a 302/c4 car looked like it belonged there.. But could have came from a versallies
  14. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    "Posi" is limited slip. It's Chevy's term for limited slip.
    All of these terms refer to "Limited-slip" differentials:
    American Motors: Twin-Grip
    Buick: Positive Traction. Gran Sport models used the term "Limited-slip"
    Cadillac: Controlled
    Chevrolet/GMC: Positraction
    Chrysler: Sure Grip
    Dana Corporation: Trak-Lok or Powr-Lok
    Ford: Equa-Lock and Traction-Lok
    Jeep: Trac-Lok (clutch-type mechanical), Tru-Lok (gear-type mechanical), and
    Vari-Lok (gerotor pump), Power Lok
    Oldsmobile: Anti-Spin
    Pontiac: Safe-T-Track
  15. bigblockmav74
    1974 maverick
    My car is not a posi !! But yes when one spins the other joins...not both turning at same time from the beginning like a spool or welded spider gear.
