Potential engine swap donor
Discussion in 'Technical' started by dtb147, May 20, 2010.
  1. baddad457
    Offer him $750 for it and go from there.
  2. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    In my opinion the only way to get use out of an AOD economy wise is to use EFI. If you lug a carbed engine it will not get good mileage.
    I once had a 351W in my 71 F100 with an AOD and 3.70 gears. cruising around the country side it was pretty much lugging all of the time. I never could get over 13 mpg with it. Tried 3.25 gears and it was worse. I didn't have any other gears to try.
    Lugging a carbed engine can open the power valve in the carb a lot more than is should be is all I can figure.
    I kept my rpm's down on the interstate which I liked but even running 65 or so it still felt like it was lugging all of the time.
    I think the only way to get a real benefit from over drive is to be using an efi set up
    I pulled all of that drive train out and dropped a mild 460 in there with a C-6 and 3.25 gears and can average around 15 mpg.
    clint
  3. PaulS
    Cdeal - your experience is one of many. That's why I try to talk people out of using the AOD unless they are running very low gears.
