powder coating
Discussion in 'Cosmetic' started by PINKY, Sep 7, 2008.
  1. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    that sounds technical :clap:
  2. rayzorsharp
    Well, I've heard of Sissy Bars, I guess now ya got Sissy Springs!!! :rofl2:
  3. Dave B
    LDO Springs?
  4. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    ha ha......with a name like PINKY you should expect nothing less :p
  5. rayzorsharp
    I know...they're just so...cute!!! :p
  6. 75 Vomet
    75 Vomet Member
    Shickshinny, PA
    75 Comet GT, 03 Ranger, '11 Fusion,'13 Escape S
    Did some research. Some info. on Wikpedia says 450 degrees F., but our tech gut a work opened his magic book. I don't know the exact material Ford springs are made of, but most springs (industry wide) are tempered at 850 degrees F. to 1050 degrees F. :)
  7. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    thanks for the info (y)
  8. JD71
    JD71 John Kenney
    mississippi
    71 maverick
    where do you get a big oven and how much are they? would a heat gun do the job? one that goes up to 1000 degrees
  9. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    do a search on
    Summit
    Eastwood
    Caswell
    They do sell heat lamps for bigger pieces.
    Its all about the heat, so sure a gun would work.....as long as you can control the temp. Would suck to hold it for 30-40 minutes :16suspect
  10. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    It is probably the machinists handbook and the temperatures he gave you is commonly used to anneal or normalize your material.
    "850 degrees F. to 1050 degrees F" at this point the metal starts to become a maleable state and the granular structure starts to realign itself.
    The 400 degrees F. won't hurt it
